will ride height adjust affects camber and toe?
i've noticed my 1995 corvette is a little bit higher or right rear corner, about 3/4" higher then the side. (seems to be a common problem)
So I would make a ride height adjustment all by myself without digital instruments just a ruler, but won't that this adjustement will affect toe 'n camber
Anyone knonws?
Anyone knonws?
Anyone knonws?
Anyone knonws?
You can easily change the bolts on the rear suspension to counteract the body to be more level, the standard ones have a split pin to prevent the nut from coming loose.
The shop manual will have the correct ground clearance specs, you could adjust the rear suspension to level it out and have the correct ride height. You may get away by doing that and the alignment will be in the ball park.
I would get it aligned, a good idea to do that to prevent uneven wear on the tires.
Yes the camber and toe in will be affected with a ride height change and need a 4 wheel alignment, how much it is affected is determined by how much of a change in ride height.
In my experience (coil overs on the 93) it affects toe more than camber and the front more than the rear.
However, I will bet that like me, it has been a long time since you have had a good alignment. So why not.
Have you got, some specs for ride height for 1995?
In my experience ride height depends a lot on the slope of your driveway and the curbs and bumps you normally traverse. Until you get very (way too) low you are not adversely affecting suspension geometry, so every Corvette I have ever had has been adjusted down a bit. Normally on stock bolts for me, as if I want to go much lower I go to coil overs. My 93 got coil overs more as a mod fest thing, but I have had to raise the car when I moved back to California as the roads are so crappy here compared to Las Vegas and/or Scottsdale.
Both my C5 and C6 Z06s have been lowered on stock bolts.
Take a look at the pics, don't you?
Mine is the same way. I could never adjust it out to be correct. I purchased longer bolts, new spring, sway bar bushings. I have not replaced the link arm bushings yet. The front appears to be good.
I see what you mean. It has the old "Rake" look. There is a spec and it is available in the Helms. Should be the same for any 92-96. Unfortunately mine is over at the garage with the older cars. The spec picks several specific points on the frame (and on the body) and measures from that point to the ground.
Sorry I can't put my hand on one now.
Also right rear is a little bit higher thatn left rear.....i suppose that this was happened when previous oener had raplaced shocks, infact bilstein are on my car, they shouldn't be as OEM equipment? Is right?
Park the car on a flat level surface. Measure the distance from the ground to the under-side of the fender lips. The rears should be a bit higher than the fronts, but never lower than the fronts. I dropped mine about 3/4" in the back, so they are now about 1/4" higher than the fronts.
Bilstein are OEM.
FL---26 15/16"
FR---26 15/16"
RL---28 1/8"
RR---28 5/16"
I don't understand why RL is different than RR
Don't use the distance from the wheel well to the ground. The body components are not always exactly the same even when the body was put together in Bowling Green. And if the car was ever damaged, it may not have been repaired exactly as new so any measurement would not necessarily be the same as before.
Ride height is measured from certain measured spots on the frame rails to ground and with a specific cargo load. There will be information in the FSM about ride height. And ride height is different betwee coupes and convertibles because of the X-brace found on 'verts.
Shocks should not completely control the vehicle height. Note that the OEM rear spring bolts have a castle nut and a cotter pin that goes thru a hole in the bolt shaft. That makes it impossible to change the rear ride height unless you replace the bolt. Longer bolts will lower the rear of the car and "Nyloc" nuts are used to get the desired ride height. Once that is done, a 4-wheel alignment should be done.
Always hoping that car wasn't damaged
I've checked my rear spring bolts, right hand bolt end is shortest than ledt hand... About 1/4" infact distance from right wheel well to tire is 1/4" higher than left
At this point what should i do? Seems that is possible to tight a little right bolt... Though wouldn't make a mess??
Is it correct to tight right bolt this case... Or how already said herethe ride height has a lot of points need to be checked
I really believe it's time for you to drive it and "forget about the dimensions you keep mentioning.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Overthinking can be hazardous to your health.....
