Changing front oil seal on LT1
Is it very hard to remove and replace front oil seal? Will I need a special tool to remove and replace the seal. Getting the bolts out was a little hard from the harmonic balancer as I was too stubborn to remove steering cylinder. I put a new rear one in while the engine was out, but thought the front would be ok with less than 33,000 miles on it.
Id recommend if your going to do your front seal to just take your opti and water pump out too and get a seal kit that has all 3 seals and a timing cover gasket and pull the timing cover off so you can install them on the bench. Much easier to get them in nice and straight that way and youll kick yourself if a couple months from now one of the other two seals starts leaking. You not talking more then a couple more hours work and it also gives you a good chance to clean everything up good.
Use a new bolt on the balancer hub
I did put a new one on my LT1 though, because I had to go to ace anyway to get a longer bolt to install the hub, and the old bolt had a torn up hex head. I've thrown away just about all my sbc stuff long ago.
Because there is no risk. The small block chevy has been around how many years now?.........there have been millions of every bolt on one reused without failure, as long as nothing stupid is done like over or under torquing.
Do you replace your lug nuts and studs every time you take a tire off?
Do you replace your drain plug every time you have the oil changed?
Why risk a wheel falling off?
