Starter or VATS?
Starter or VATS?
I got code 46 (VATS "theft system failure") when I tried to start my car today but with all the on/off testing I did yesterday I think I may have fried the starter. How can I tell if it's VATS related or a dead starter?
You could bypass the ignition switch and go directly to the starter to check if the starter is bad ..I have a hand held push button starter switch to spin the starter, but you could just use a jumper cable from the positive battery cable lug to the ignition wire lug on the starter ,this would spin the starter but you have to be careful when doing it this way .Even with a bad starter you should still hear the solinoid click once you get the vats working again, unless the solinoid is fried also.....WW
No click from the started at all so I'm guessing VATS is the culprit. I have vats bypassed in the chip and ordered a key bypass to take care of that bit.
You should be able to hear the starter enable relay clicking (behind the DIC) when you try to start the engine. If that is not happening then your problem is not the solenoid or starter.
There are 3 parts to the vats system...If you have done the delete in the chip, you still need to do the bypass/delete for the key and the "starter enable relay bypass"...All 3 must be done to completely eliminate vats from the car.. The vats delete site with all this info is called ( Vatssucks.com ) ......WW
I'm waiting for the last part of the bypass (pass key bypass from mid America). Im hoping it will be here by Friday. I'll post my results then
BTW: I emailed Corvettejoe and it turns out that while I am fooling the system with these bypasses it wouldn't matter if VATS was bad or not with these bypasses in place.
