Brake Upgrade: C5 brakes on a C4
Ok, so I'm ready to start planning my brake upgrades for my car. Car is a '92 coupe with 2010 OEM rims (18*9/19*10). I want to upgrade to atleast C5 brakes and rotors (tired of my '03 F150 stopping faster than my Vette does). So what I'm looking for now is a parts list or a recommendation for a upgrade kit to use. Also, are C5 and C6 brakes basically the same (rotor and caliper wise that is)? If C6 brakes are better, can I upgrade to C6 brakes on a C4(I do have C6 rims)?
Vette Brakes has a C5 front brake kit with everything you need. It's pricey at $950 plus shipping , but you get everything in one order.
If you want to collect the parts yourself, try eBay for the custom adapter bracket. You will need the C5 caliper abutment bracket, calipers, rotors, guide pins and boots. Note that the only difference between the standard C5 caliper and the C5 Z06 caliper is the red paint. Use stainless braided flex lines at all 4 corners. The C4 lines from Earl's or Goodridge will work fine and will bolt up to the C5 front calipers. Use a good DOT4 fluid like ATE TYP200 or MOTUL fluids.
I would suggest using the C5 Z06 pads up front and something like Hawk HPS pads for the rear. The C4 rear brakes are nearly the same as the C5 rear brakes in terms of size and performance. The C5 rear brakes use a drum style parking brake while the C4 parking brake uses the caliper so a swap to C5 rear brakes isn't really worth the cost and effort for street use.
Max G’s
If you do not track, HPDE the car all you need are good pads and a good fluid flush/bleed. Get some Hawk HPS or their new pads the Street/Race pads.
good info, thx c4
Yeah, the kits are pricey. I don't mind buying the parts separately if it will save money.
Thanks for the info about the rear brakes, I was wondering about that too.
What about C6 brakes?
I do circle track race once a week, one of the main reasons for this upgrade. Plus, like I said, I don't like my "plain jane" '03 F150 having better stopping power than my Vette does. And yes, it is a substantial difference between the two.
Not knowing the wheel branding you've got a C6Z06 would maybe do if your pockets are pretty deep. You need the StreetShop package for the rear E-brakes but then it's all done and you've got the "bling" also.
I believe it's covered pretty well in this thread but there's maybe a tweak or two that's come along since. The caliper packages are likely a bit less expensive to come by since the serious souls are upgrading to yet better and bigger. Well bigger maybe but who know if better.
https://www.corvetteforum.com/forums...-and-pics.html
thx WVZR-1, I'll read that thread thoroughly.
edit: ok, my pockets are not even close to being deep enough for C6 brakes Just the calipers and rotors alone will cost 3-4 times as much as a C5 brake upgrade package with everything included.
You can do the C5 upgrade much cheaper if you source the parts individually and find some deals on Ebay. I bought rebuilt C5 calipers w/ abutment brackets, as well as, adapter brackets on Ebay for $250 or so as I recall. After rotors, pads and SS hoses I was in for about $500 give or take. It was a fairly easy project that made a huge improvement over my base brakes.
Not sure if I want to do that since the car is a semi-daily driver also.
The DRM is very good for daily driver.. there is some data on it here
With my c5 brakes, hawk pads and proper break/bedding in process my c4 can cause abs at speeds up to 120mph, speed at end quarter mile
Have you considered just going with some high performance pads? Hawk and others make some good pads that can work for your braking needs and still be streetable. A good set of pads and rotors can make a huge difference without costing a ton of money.
Adapter Bracket Installed
Umm. C5 brakes are not An upgrade over a c4 with j55 brakes.
C5 brKe rotors are not a full 13" diameter like th c4 j55 are. Sure they are a little heAvier, which is good if you like unsprung weight
C5 brakes were what non j55 people used to do before the c6 z06.
If you are going to go thru the trouble, do a conversion to c6 z06 brakes or j55 if your pockets aren't as deep
Whatever you do I recommend hawk HPS pads or HP+ if you don't mind squeaks when cold
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Rotor Diameters/Thicknesses:
Base: F 325mm/R 305mm
Z51: F 340mm/R 330mm
Z06: F 355mm/R 340mm
ZR1: R 394mm/R 380mm
All (3) variants Rotor thickness (with exception of ZR1): F 32mm/R 26mm
I think the C5 calipers are better than J55.
I also did DRM spring, braided lines and hawk pads and went up to ZR1 sized tires...
Stops a tad better..
Max G’s
