datamaster, glowing red headers. gurus please help
well this is the start of this thread and the newbie questions and eye rolling... i'll just get out of the way now.
this is a first for me i have never messed with software/programming so please no abbreviations... talk to me like a child lol
i loaded the masterdata and already I'm stumped on even getting it to read the pcm( see picture) it says the adla cable is good but the ecm is not reading.
the issue I'm trying to resolve is after the first start the headers got hot enough to turn red. tune was done by pcmforless. moving it from the barn to the garage it was not very responsive either. any info would be great. guys I've built carbed motors plenty of times and know for some its no different for fuel injection ... but for me.. i'm just lost trouble shooting this issue. really hoping the datamaster will lead me in the right direction.
Just had one the other day did not have the spark plug wires on right they need to click twice
.. i dont even know how to adjust timing on this motor. doing the mechanical stuff for the build was easy but working with the pcm has me stumped. i was hoping this datamaster would lead me in the right direction but i cant even get it to read the pcm. at $300 i was hoping it would be a little more user friendly.
The year would help. And how it ran before you worked on it and what have you done.
94 lt1 stock bore
fully worked heads, rollor rockers, springs, ported runners and bowls
ported intake
1000cfm maf housing
electric water pump
obx long tube headers to true duals
pcmforless mail order tune
built 4l60e with 2800 stall
3:54 reat gear
i think thats everything i did to it.
ported intake
1000cfm maf housing
electric water pump
3:54 reat gear
Oh boy... Umm .. I dont know lol i emailed tuner cat and told them what i had and they sent me the tunercat and datamaster stuff. It was the pro version of it.
I know guys im an idiot.... Ill say it so you dont have to lol but i have a nicely redone and built vette ive been working on for the winter and i want to drive. Ive called every shop in the area and they are all to busy to take on my car... Let me rephrase that.. Every performance/trusted shop. Ive had a few "sure we can figure it out" guys that have said its my fuel pump..... Brand new 390lph fuel pump. Anyway im desperite and stupid... I mean lost lol
Ill try and help you. First make sure you have (Datamaster EE). Datamaster works on cars other than the vett. The EE designates Corvette. Note the EE designation at the upper left part of the screen.
I know too lean is no good either, but I've never EVER seen my vette run lean (despite my and other's best efforts).
Pull the dipstick, give it the sniff test. Smell like gas? If so, you're rich....not lean.
OP you also need to go to Setup>Vehicle Type and chose Y-Car, A/T.
EE basicly actually covers all 94-95 LT1.
Thanks guys, lots of good replies. These came after i was in bed so i will try these after i get home from work today and let you know what i get.
Really ...really appreciate it.
PS
Yes you can build a timing pointer and check it with a timing light. However unless you convert to a carburetor datamaster is a better option then a timing light.
I do have cats tuner software as well. Im in the car now. It wasnt on"y-vette" so i switched thaf. It is the datamaster EE got the port figured out and it worked.
Attached is the recording at idle for about 2 minutes.
DTC Diagnostic Trouble Code. Datamasater is showing there is at least one set. IN Datamaster click on View>DTC Codes post what it tells you.
