clicking noise in L/R
I have a clicking noise in the left rear caliper and the Service ASR light is on when I go into 1st gear, also ASR off light is on. I've changed the fluid and inspected and cleaned the wheel sensor. Bad Caliper causing this? the car runs and brakes fine otherwise.
have you gone into the on board diagnostic, to pull the trouble code and verify that it is the L.R. sensor, the clicking brake caliper could be unrelated.
Here is a link to a basic code recovery procedure for most C4 years if not all
http://www.corvettebuyers.com/c4vettes/codes.htm
there a section for the brake computer to
Hi
here is how I fixed my rear clicking sound,
https://www.corvetteforum.com/forums...-fixed-it.html
Hope you can help...
