Bad ignition coil
Bad ignition coil
I have replaced cap rotor plugs ignition coil. The car was sputtering when shifting it felt like a back fire ...so I replaced the coil a second time it worked for about 400 mile and it started again this time I replaced it with a mds ignition coil and it's working for now ....what would cause the coil to go so quickly
a bad wire?
A spark with nowhere to go is tough on coils. Run the engine in complete darkness and look for a steady spark jumping out somewhere.
This a big cap or small cap HEI dist?
Make sure you have the ground strap on the coil, and that it's making good contact...WW
