Cracked headlamp motor case
Hi, folks—
Anybody dealt with trying to repair a headlamp motor cover for an 84? My pass side headlamp motor was skipping teeth, so I rebuilt both sides, driver’s side worked OK before, now it works perfectly, pass side now doesn’t work at all. Disassembled again, turns out that the pass side motor cover was cracked right across the headlamp axle, which is allowing the post to flex just enough for the small gear to skip as it takes the load from the metal gear. The motor itself is working fine, I just need the cover to hold the headlamp axle in the correct position.
Tried to epoxy the thing, epoxy didn't stick. Not sure that I can weld this with a soldering iron, it would thin the material a little and might just cause it to break again.
Any ideas on a long-term repair, or sources for a replacement, would be greatly appreciated--this is a long-term on-and-off project that's down to this one issue to get it re-registered and back on the road.
Thanks!
Thanks!
Look on ebay
I'll try to get one, have to pull the whole assembly off and then remove the motor. Basically, the crack starts on the outside of the large gear well, moves over the small gear well, up over the back of the small gear axle well, and then down onto the flat area just next to the small gear. It seems as if the gear is being pushed outward into the plate when the motor hits the end of its travel, and it flexed enough times to finally split. Not 100% certain but it seems as though nobody (feebay or several recyclers) has just the plate available, so I'm going to have to either try to find a whole dead motor so I can scavenge the plate, or replace the whole unit, which just annoys me because it works fine otherwise.
