95 starter relay location
The TSB referenced:
VIN specific TSB - I believe the location mentioned is likely correct and it would/could be the left of column "closest" to the column. I don't have a '95 FSM and I don't recall the '95 format but if someone had a '95 FSM they could confirm from either 8A-30 or if the format changed maybe from the 6 section to the component locator in the 8A-201 section.
In '95 the terminology may have changed a bit "THEFT" instead of "STARTER ENABLE"
Well, that accurately describes my problem, but my VIN is 114167. Ruled out the battery yesterday, so I was going to check the relay then the starter. It started Friday morning and continued through this morning, but didn't do it when I left work at 3:30. The "security" light is not flashing when it does this.
5th Gear
help! starter enable relay
Can anyone tell me where the starter enable relay is located on the 95? I am dead in the water and this is my only transportation......checked ignition sw. good, checked starter motor, removed clutch sw. like new.......where is the starter enable sw. on the 95? I must be tired, where do I start a new thread?
