1995 antenna does not properly work
Good day all
My project for yesterday was "to replace antenna" on 1995 corvette
Well i've done this job, but was not a big deal
The problem is and was: 4th antenna part, the larger one does not come out when I insert contact sleeve...even old mast was stucked in
No contact sleeve and nut only antenna works, all four pieces come out, so i would assume motor and nylon cable are ok....
the contact sleeve pushed in stucks me antenna 4th part
What can I do? I've already tried to enlarge sleeve a little, but when put inside motor housing it is came back to be tight
