Fuel Pump
Ok, spoke a little too soon, in 4-5 min its bled off 4 psi, now at 40 psi
Ok pull the vacumme line off the fpr and sniff
Now, 6 mins later, its at 39 psi
My 94 will hold all night and all original stock. I would fire it up and work it a few times to make it die and sniff your hose again. And gas smell in the oil?
Pro Mechanic
#33
Wish I would have thought of that. Had to buy those this morning to do this with. The needle nose were actually a little less expensive, besides having to go to three different stores to find two pair of 10" visegrips wide enough to fully close off the hose.
#34
No gas smell in the oil
#35
Tried clamping off the hoses with the engine running and let it stall car. Car would shut off immediately upon clamping either hose
#36
Ok nothing jumping out at me. If it was me I would go get a differant fuel pump and fpr and I would change the pump first and see if still no go the fpr. Not one to through parts but would at this point. Any ideas out there that I missed? But first would pull the pump and make sure that rubber hose is good and not leaking.
#39
#40
