Some tips to replace vanity mirror and passenge. r side floor light
Hello....
Know some one how to replace vanity mirror bulbs, once i've removed plastic shield, there's no way to remove that little bulb from its socket..
Also i've replaced driver side floor bulb... Would even passenger side... But seems it's a little bit more complex...infact the floor plastic shield has only one side that has to be grabbed, the other has eletrical wire... In passenger side i'm not be able to determine which is the right one
If you pry on the wrong end there is no possible way it will come out without breaking something. I suggest examining the driver's side lens and see which end is the correct end to pry on and then transfer that knowledge to the passenger side. I'm sure the lenses are identical.
