Turn signal and some lights not working
Hello,
I have a 1985 Corvette and I have a few issues with the turn signal and lights. I'm thinking it's the flasher but there may be more to it.
Thoughts?
- The left turn signal works fine, but when I activate the right turn signal, the arrow on the dash doesn't blink, it will stay on continually.
- The passenger side brake lights were not working. I replaced both bulbs, but now only the left light works (on the passenger side), while the right one does not work. If the turn signal is on, the left one stays on (doesn't flash), and the right one will not turn on at all. If the brakes are pressed, the left one stays on, and the right one will not turn on at all. Everything on the driver side works fine.
- The hazard lights all work. All lights flash and the dash arrows flash too. The only light that doesn't work at all is the far-right brake light on the passenger side.
- A similar issue happens in the front. If I turn on the right turn signal, the light will stay on, but it will not flash.
Thoughts?
That's a long explanation to say that the far right brake light bulb doesn't work! Is that boolean logic?
If you've already replaced that bulb, are you sure the bulb is installed correctly? Did you use any dielectric grease in the socket? Could the bulb be defective? It's a known fact this bulb is difficult to access, but it looks like you need to pull that light bulb again to check it out. Sorry!
I've used zip-ties and rubber bands to hold the bulb and socket together but they just won't stay on there. I also wrapped some aluminium tape around the base of the bulb so it could have a better hold but it did no good.
I scrapped the old grease off the socket and I applied 'Electrical Insulating Compound' to it and the end of the new bulb, but it didn't do much of anything.
I'm considering just buying a new socket, good idea?
There's a spring inside the socket that should keep the bulb tight. If the wires into the bottom of the socket are kinked, this spring can't do its job. Could it be that simple? Are the two contacts in the bottom of the socket clean? You are installing the bulb in the proper orientation, not 180 degrees rotated? You've probably noticed the offset pins on the bulb, but I had to ask!
What is "electrical insulating compound"? That doesn't sound like dielectric grease. You're trying to keep moisture out of the socket, not trying to prevent electrical continuity inside the socket.
I don't believe the C4 sockets are constructed in the fashion you're mentioning and that I remember well. I believe all of the C4 product were the newer 90* approach sockets that didn't have the phenolic disc, the spring and the rivet on wire contacts. You've got one so it's likely that you should know but I just can't place the earlier type with a spring being used here. Is there?
The brake/tail light bulbs in the early C4's are 2057, which have the round bases with offset pins on the sides to assure proper brake/tail orientation. What is the part number for your ZR-1? I wouldn't be surprised if the later 'vette's use the more modern push-in base bulbs. The push-in bulbs don't require a special orientation. The new style bulbs work right regardless of orientation.
This is a correct socket for any earlier C4, the construction changed again later in the production, maybe '94. Still 90* but different terminals and retention.
WV, you are right. I had to pull a tail light on mine to refresh my memory!
Boolean, is it possible you wern't twisting the bulb after pushing it into the socket to lock it in place? You mention that the bulb works when you push it in, but you don't say anything about twisting the bulb. If the bulb won't twist, rotate the bulb 180 in the socket and try again.
I just twisted the new bulb in, and works just like it should. Thanks guys. You just saved me time and money.
