Forced Air kit guys....
I want to take this off of my car before insurance takes it ... someone who has installed this, what all comes with the kit so I know what i need to take off?
I'm pretty sure it's 4 small bolts that you take out from the front ... then pull the piping and the air box lid... So will i just need to find a stock air box lid then?
Re: Forced Air kit guys.... (Glock'94)
Easy to remove.
1) Take out 2 screws (Torx) below the Air Inlet Grille. These are the original License plate cover screws.
2) Pull out the grille and disconnect the air hose.
3) Go to the engine side and turn the air hose to release it from the air filter housing, then pull it out.
The pieces are Grille with diffuser, Air Hose, and Air Filter Housing Top.
The original License Plate cover can be reinstalled.
I just installed the a/o forced air kit on my 87 today. :)
The kit included a support bar that has an arched area to fit over the top of the inlet tubing. It mounts/connects the area that was cut off the front support....I would definately pull that off also.
