Optima red top not fits
Hi all
Yesterday my battery Duracell died. Purchased new optima red top, the only battery available for corvette here in italy. Cery expensive
unfortunately it won't go in battery holder... To width about 1/2" any suggestion?
I've git this one, may is not the right one?
http://d26maze4pb6to3.cloudfront.net.../RedTop_78.jpg
Hi all
Do not cut anything on the battery in an attempt to make the top clear the brace. If you must, remove the brace and have the brace modified to clear. If you do this there should be no issues with what I believe they call a D75/25 now.
I realize that your choices are very limited BUT a group 75 battery is very popular with many, many GM products and you may be able to do something other than the Optima in the GRP 75. I would try if you can.
Just waiting for 'optimA jim' to get on here and tell you how great of a battery the optima is and thanking you for your interest.
Then next he will tell you how optima doesnt make a battery for the c4....
I believe the OP mentioned finding an Excide product and if he has most of the Excide product line is "first class" product. I believe he'll likely post back.
Optima
I took a few pictures. The positive has plenty of clearance, the negative is a little close. I put a couple of plastic covers over the aftermarket terminals.
It's unusual to be able to use a GRP 78 battery but you seem to have. It would seem likely that the tray would have required some modification but you mention not. Interesting.
My car instead Have it on the low edge,
Also i've tried to put in a grp 78 ( pic down here), nor yet go in battery tray...
Where did you fit cables on top terminals or front?
I used the side terminals. The top ones are being used for my stereo. The battery fits fine in my battery tray as you can see. Maybe the trays differ over the years. I have a 86 coupe.
For the tray replacement that you have mentioned... possible but don't know which part is installed on your car
I would suggest you to connect your stereo negative cable on a frame ground point instead of battery negative terminal
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I used an Optima in my 91 and yes it did require the CC support bracket to be slightly trimmed to clear the top post as WVZR-1 stated. It is my understanding you void any warranty if you trim the posts.
Part # 8022-091
Model 75/25
Part # 8022-091
Model 75/25
Sure, it is a no sense to put a little battery tray, but it is...
