P0336 and P0441 codes 1996
This car might send me to the grave early! I have bad cam bearing so I am having the block and heads rebuilt but I have these codes that keep popping up and I can't get ride of them. For the P0336 I have already had the crank sensor replaced and the connection are good. Could the trigger wheel be damaged causing this? For the P0441 I have already replaced the fuel cap, EVAP canister, and purge solenoid. I was told by the shop these codes are from the engine not running right and should go away if rebuilt or replaced. Is this correct or not? What sucks is that the county I live in I have to pass emmisions and it will not pass if the check engine light is on. I hope someone can help me out before I pull my hair out
