new 383 l98 runs terrible STUMPPED
good day all just finished installing my 383 but it runs terribly. it misses on idle, it will stall with my foot off the throttle and misses/surges/no performance for a 383 all the way thru the power band. To make matters worse it will back fire thru the intake when i rev it up in park. I have a mini ram with no vaccum leaks ( checked with smoke machine), new 30lbs injectors,230/236 cam and yes i have a tune from PCMforless for all of it. I have checked the injectors and have 16.4ish ohms on all cold and 18ish when hot. fuel pressure is at 48lbs and will hold it and no fuel in the vacuum for the FPR. i also checked the injector pulse with a noid light all good there too. advance is set at 10 degrees with the EST unplugged. with it plugged in the advance jumps all over the place from 15 to 30 btc then to 0. I don't know if thats normal or not. So removed the distributor and noticed that i have a lot of play on the shaft ( up and down) and the shielding on the pickup coil is gone BUT the resistance is within specs at 850 ohms and it doesn't seem to have continuity to the body. any ideas or help would be appreciated
thx Chris
thx Chris
if the timing is jumping around when its controlled by the ECM then your computer is probably fritzed !
there is every chance that while you have been installing the engine etc, the ECM may have got a power spike.
the only way to really test is to put a good ECM in (beg, borrow, steal ?)
If it back fires through the intake our intake valves are mis adjusted and one or more are hanging open.
Readjust your valves and the back firing should go away
My 383 will run with the stock 86 tune, so don't let anybody tell you that you need a tune to run it.
It is not a firehouse with the stock tune, but it runs pretty good up above 2000 RPM.
If the timing jumps around, it could be worn distributor bearings, but since these engines run below 2500 RPM most of the time, I would not think it is the distributor.
I would believe it might be a dirty plug on the distributor 4 pin plug, or a problem with the distributor module over by the heater. Unplug the module, and the engine will go into limp-home mode, and the engine will operate on look-up tables. If the engine smooths out, it might be worth while unplugging the battery, and let the computer sit for about 3 minutes with no power on it then plug it back in and try it again. or change the timing module that you unplugged.
But adjust those valves, no engine will run right with no compression on a couple of cylinders.
While you are at it, check the plugs. if any of them are black or smell like gas, you have a leaking injector in that cylinder.
Remember, all of the injectors made are mass produced, and you might have got a bad batch.
When I put a cam, miniram, and headers on my '85 Corvette with 350 engine, my tune was thrown off so bad that the thing barely wanted to run. I too had backfires out the intake which was solved by adding more acceleration enrichment fuel. Lean conditions can cause backfires out the intake, which was the case with mine.
I firmly believe that the tune is a good contender as being the problem.
383 runs terrible
Hello. It does sound like like a timing issue. You might be off a tooth or 2 when you installed the distributor. That's about what a timing issue sounds like. Not sure about the ecm and how that would make it run. Try resetting the distributor back in the engine again. If that doesn't work try another distributor. Then look at ecm if all else fails.
thx Chris
thx Chris
what year is she?
the 85-89 have a Maf sensor, that needs to have a modification (sample tube) for the larger injectors. The tune my have taken care of it another way.
The main culprits.
Injector connectors, they can break internally if pulled by the wires.
Also inspect the connections for corrosion, you can easily replace bad injector connectors. they batch fire one side all together, then the other. There is no problem swapping them to test, for example you can swap cyl 2 an 4 or 6 and 8 or the other side 1 and 3 or 5 &7 for a test.
The valve lash, check compression if the valve last is too tight you will have a valve slightly open.
A simple check from my toolbox ...
when cold start the car and run for 10 or 20seconds, now feel the exhaust pipes at the head. if one or more are cold you know what cylinder is causing the problem.
I found my new 383 lifters only need 1/2 turn from zero lash, not the factory 1 turn. Had a few dead cylinders. was an easy valve lash re adjustment.
Running high fuel pressure did not affect my engine when stock, 45-48psi was fine on the standard injectors.
Good luck.
Update so I put in a D.U.I distributor complete assembly at the same replaced the ECM with a rebuilt unit ( no PROM) and still the same fu.... problem. I haven't redone the valves but did do a compression check and have between 165 an 175. I have the fuel pressure at 48lbs because that what the instruction from Tpis say to do for the mini ram. Im getting a new chip from PCMforless ( spoke to them and they graciously will send me a new one ) hopefully that solves my problem.
Indeed; mechanical B4 software, which includes my antique and trusty vacuum gauge!
