88 heads and mainifold
Hi guys
I have. Stock std 88
Just ordered headers and having a custom exhust fitted
I would like to replace heads
What do u guys recommend ?
Will also do a cam at same time
What do u guys run ?
Will the stock mainifold be enough
It's hard in Australia to get the right info
Thanks dale
Thanks dale
Received 1,401 Likes
Current D-port 113s are a good head, it depends on what you want from the car. Heads and cam and intake should be matched together, and which one you get depends on what you want from the car.
The torque # is always higher until the engine reaches 5200 rpm & gets into the HP curve. The entire TPI, heads & exhaust are choke points, the engine basically hits a breathing wall at 5K.
113 heads have small runners + valve lift cannot exceed .500 without incurring retainer to guide interference + the valve diameter is small. Combustion chamber CC is 58. The heads need some work for bigger cam use. They are good heads if torque is the concern.
If 400 hp at the wheels is the goal you need 6000+ rpm which will require an intake, heads, cam, full exhaust & a gear. Depending on the new head combustion chamber size you may also need domed pistons to reestablish compression ratio. For a street vehicle on pump gas dynamic compression ratio should be your concern it will basically be determined when the intake valve closes completely. IE: intake valve event after BDC (the beginning of the compression stroke).
