95 LT! 383 w/hotcam which FPR to use?
I also upgraded to 32 lb injectors. Will the OEM Fuel pressure regulator be ok for this upgrade? Or do I need to go with an adjustable FPR? What fuel pressure should I be looking for? Thanks guys.
The tag that was attached to the injectors says 32lbs @43.5 psi. So, looks like I can use an OEM FPR. Thanks for the reply.
