1984 corvette
1984 corvette
I'm having a sputtering problem
I replaced fuel filter and put better fuel pump
in it runs better but has slight miss
runs strong
but go for ride in little traffic it sputtered
when give it little gas give it more gas it smoother out
Need help can message me here or
gmjm0786@aol.com
runs strong
gmjm0786@aol.com
Check your air filter and clean your throttle body and make sure it is tight
Look for sparks under the hood when dark
vac leak !!!
tighten all bolts on tbi s and manifoil , pull of the tube to egr solionid and block it on the tb !! look for dripping from the injectors on a running engine !! clean the iac s !!
This is what I've done so far checked and tighten all manifold bolts and
hex bolts on injectors
found one cracked vacuum line cut n fixed
one of the fater vacuum lines that run over to drivers side unit think it's cruise control
pulled plug on map sensor and car did nothing plugged back in motor went to norm
with slight miss
my son is picking up a map sensor
will run car tomorrow
Looks like and was told injectors and throttle bodies were gone over can see thread tape
This is where I'm at right now
with slight miss
