My radiator is without drain plug! Why?
Old 09-16-2015, 09:07 AM
Christi@n
Christi@n's Avatar
Default My radiator is without drain plug! Why?
As a title mine 1995 radiator has no drain plug...
Noticed last march when replaced coolant, don't care about this i remove lower hose and drain it however, just i'm asking if is there a possibility that radiator is not a corvette radiator??
Old 09-16-2015, 09:18 AM
antfarmer2
antfarmer2's Avatar
my 94 drain is on the pass side kinda set back look again
Old 09-16-2015, 09:43 AM
Churchkey
Churchkey's Avatar
Should be lower right side below trans cooler line see pic in link.
https://www.radiatorexpress.com/prod...FUE7gQodMA4AgQ
Old 09-16-2015, 10:24 AM
antfarmer2
antfarmer2's Avatar
and if you did not pull your kock sensors you did not drain it or replaced all of your coolant and left a bunch of crap in there.
Old 09-16-2015, 11:35 AM
Christi@n
Christi@n's Avatar
Removed even ks, drained al coolant, the most part of coolant is in block no in rad
About drain engine.. Do you know: isnt there any engine drain plugs...
Most prefereable to remove plugs instead Ks... I think
Old 09-16-2015, 11:36 AM
Christi@n
Christi@n's Avatar
Yes I know it is not right there....and even not left side
Old 09-16-2015, 11:38 AM
wydopnthrtl
wydopnthrtl's Avatar
Someone must have put a cut rate rad in it at some point in time. My 95 original rad had one and the new (thicker) one I put in has one.
Old 09-20-2015, 06:33 PM
Christi@n
Christi@n's Avatar
I was seeing rad today...and confirm no drain ****...
The strange thing is that it has no plastic edges but they are metal made seems to be something like iron cast or alu cast black painted
Old 09-20-2015, 06:54 PM
c4cruiser
c4cruiser's Avatar
Sorry, but the knock sensors are threaded into what the early Chevrolet Gen1 blocks had as drain holes. There are no other holes/plugs at the bottom sides of the block.
As far as your radiator, it sounds like it's an aftermarket radiator, not an original GM part. The side tanks would have been plastic, not metal. The OEM radiator will have a drain plug at the bottom right corner in the plastic side tank and would face to the rear.
But I can't imagine that an aftermarket radiator would not have a drain plug.
Old 09-20-2015, 07:06 PM
Christi@n
Christi@n's Avatar
Yes seems to be an aftermarket or something like that....
Infact all OEM or equivalent radiators have plastic edge....and drain plug
However think my rad is a solid metal piece... Not crack inclined
Old 09-21-2015, 10:20 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
"Not available in the gehtoo models"
Old 09-22-2015, 04:09 AM
Christi@n
Christi@n's Avatar
Ah ah ah...i've got it
I've meant other thing ( not fracture inclined )
Old 09-22-2015, 06:42 AM
WVZR-1
WVZR-1's Avatar
Received 2,271 Likes on 2,032 Posts
GM/Harrison and many OEM's deleted the drain-**** feature on most radiators many years ago. Certainly any C4 "production" should have a drain-**** but a service part from ACD/GM these days likely would not. Not having a drain-**** can't be considered identifying a radiator as an after-market BUT if you don't have an aluminum core and plastic tanks then your radiator isn't an OE.
OP - If the radiator has been replaced you should quite likely be able to tell by removing the upper radiator support (often mistakenly referred to as shroud). The hardware attaching both halves is a tough reach and generally they're not put back as they were but inverted for an "easy reach".
Is the emissions label/vacuum routing label on the upper panel? I believe a '95 label should be on the upper panel. If NOT maybe this car has previously had a collision repair and that might explain the "non-stock" radiator.
Old 09-22-2015, 07:41 AM
Christi@n
Christi@n's Avatar
Yes it is
Old 09-22-2015, 07:43 AM
Christi@n
Christi@n's Avatar
Have you got a pic about it?
Old 09-22-2015, 07:45 AM
Christi@n
Christi@n's Avatar
At this point I'm pretty sure radiator was been raplaced... With what I don't know
Old 09-22-2015, 08:16 AM
WVZR-1
WVZR-1's Avatar
In this image the bolt #8 is originally installed as the image suggests "up through from the bottom" but when reassembling the cooling module most will "drop the bolt" from the top. Not always but most often ..
http://www.wholesalegmpartsonline.co...category=19545
Old 09-22-2015, 05:24 PM
Christi@n
Christi@n's Avatar
Will take a look
Do u usually buy parts fron wholesale?? How is it?
To My radiator is without drain plug! Why?
Quick Reply: My radiator is without drain plug! Why?
