Manual transmission swap..
I was looking at the mcleod hydraulic throwout bearing #1345... Says it's for the corvette 6 speed 89-96.. That one should work with the normal style clutch and flywheel correct? Also do I need to use a spacer between the bellhousing and block? I was searching Google and read something about a .100 spacer.. Is that necessary?
McLeod is for a "push style" and you don't just do an Internet order from the usual sources. You call McLeod and work with their tech support to arrive at specific shims after much required measuring. They will stick with you until completed. A year ago or so I was looking at their cataloging and it looked like the custom mounting affair for the ZF wasn't available any longer. There's various 1345 packages.
McLeod could be a good choice and they can either supply you with a package including flywheel OR if a custom flywheel is required they can direct you. I supplied an LSX for an install that required a specialty flywheel before the LSX became popular and they directed me to a specialty shop.
A search for 1345 on the CF C4 community gave 35+ results
Called mcleod and they said they have nothing for that transmission... Ram clutch says they have a hydraulic throwout bearing for it but they said they don't have any info on it working with the older engine.... They said they wouldn't be able to help anymore besides giving me the part number for my trans.. I don't want to be just guessing here.. Are there any measurements I can take to get it right the first time?
The transmission I ordered don't have the shifter assembly... Never knew how hard it was to find one. Anyone here have one they would sell? I really just need the housing... I am going with the short throw shifter but it don't come with the housing..
How much of what's in this image DON'T you have? I may have some or most of what's required. Post a snapshot of the rear of your transmission maybe !!
Guessing it's a second hand ZF trans you have? Did the previous owner mention anything about the gearbox in particular? Not wishing bad luck on you but most of the cases I have seen minus the shifter assembly describe some type of "parts only" along with the sale. Seems like people pirate the shifter assembly off the trans.
#33
Just hate it for you to go through all the trouble of collecting ZF specific parts, get everything buttoned up and then it pops out of gear under heavy acceleration or won't go into a gear and then it has to come right back out for a pricey rebuild.
#35
I'm not going through all the hassle.. I still think I got a deal even if we rebuild it at least I know it should last. Like I said I have a friend who will look it all over for me and be sure it's good before I install it. If I can get a shifter assembly I'll be set.. As soon as I can get a pic of what I need I will post it.
