93 40th Anniversary door hatch locked HELP!
Old 10-06-2015, 01:36 AM
frank151
frank151's Avatar
Default 93 40th Anniversary door hatch locked HELP!
as you can see from the picture
my drivers side door hatch is locked the lock and unlock buttons do work, (2 days ago my alarm kept going off everry 30-45min neighbors kept calling leasing officd and complaing all odd hours of the night as well if this helps with any diagnostics of this problem) what do i do to fix this? please help!
oh and i noticed it right when i hopped in the car to shut my door and it didnt shut. it recoiled because it locked hopefully that didnt do any more damage....
Old 10-06-2015, 06:25 AM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,016 Posts
Insert a tool of some sort and often your finger will work and pull on the latching device while lifting the handle to release. Unless you've demolished the latch internally it certainly should release I'd think.
Old 10-06-2015, 07:47 AM
antfarmer2
antfarmer2's Avatar
a little cleaning would not hurt either.
Old 10-07-2015, 09:40 AM
davewhtt
davewhtt's Avatar
Thats the first thing i thought.
Old 10-07-2015, 10:03 AM
WVZR-1
WVZR-1's Avatar
Cleaning never hurts BUT I believe the resolution the OP used in his snapshot needs to be considered. I believe the latch is in nowhere near the condition you guys seem to imply. Take a new look and consider "THE RESOLUTION".
Old 10-07-2015, 10:16 AM
FASTAZU
FASTAZU's Avatar
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Easy fix done it many times
Old 10-09-2015, 10:38 AM
frank151
frank151's Avatar
Got it fixed pulled the handle from inside(made sure the door was unlock from the inside latch and pulled the lock to the unlocking position. Very easy. oh and yes havent found the time to clean. Very busy at the body shop!
Old 10-12-2015, 12:17 PM
scotth48
scotth48's Avatar
Ahh, just spray some more WD40 on it to help it collect more dirt and move yet!!!
To 93 40th Anniversary door hatch locked HELP!
Quick Reply: 93 40th Anniversary door hatch locked HELP!
