What gear oil do I use?
Old 10-06-2015, 04:09 PM
DanielRicany
DanielRicany's Avatar
Default What gear oil do I use?
I've looked at a few parts store and I am trying to find a 75w-90 gear oil that is GL4 and not synthetic for my manual trans part of the 4+3 on a 1985 Corvette. Can't find it anywhere. Does anyone know a specific brand that has what I'm looking for that can be purchased locally? Thanks!
Old 10-06-2015, 04:24 PM
c4cruiser
c4cruiser's Avatar
You can use a 80W-90 GL5 gear oil. Any parts store should carry it. That oil weight is very common for a Borg-Warner Super T-10. That's the spec in my '87 owner's manual for the 4-speed part of the 4+3.
Old 10-06-2015, 05:19 PM
DanielRicany
I read online that you should only use GL4 oils for it, not GL5? Am I missing something?
Old 10-06-2015, 07:43 PM
c4cruiser
c4cruiser's Avatar
The 80W-90 GL5 specification is what is in the owner's manual. It's also in the FSM. I'll put more faith in that over "online" information. Do you recall where online you saw that? GL4 is an older spec and GL5 superseded it. Now, I have read that Muncie 4-speed transmissions do use a GL4 gear oil and most people say not to use a synthetic gear oil in a Muncie box. But remember that the older Muncie 4-speed and the newer B-W Super T-10 are not necessarily equal in terms of engineering.
There are some European and even some Asian cars with manual trans that call for GL4. GL5 will handle higher horsepower and "shock loads" much better than a GL4 oil.
confab (10-06-2015)
Old 10-07-2015, 06:28 AM
hcbph
hcbph's Avatar
Are there any bronze parts in it?
I ran into something the other year while working on a wood planer that called for 80w-90 GL3 lube for the gearbox. I could only find GL4 in that weight. During my research I found reference that true GL4 lube would attack bronze parts. I spent some time talking with Valvoline about their lube. They told me they de-something-or-other (can't remember the exact name) their lube so though it's a GL4 lube it won't attack any bronze pieces. I've used it now for about 5+ years in my planer and there's no indication of any bronze gear issues.
Not saying it does or doesn't apply here but be aware it might in some situations.
Old 10-07-2015, 12:13 PM
VikingTrad3r
Oil Producer
Support Corvetteforum!
VikingTrad3r's Avatar
Received 2,262 Likes on 1,446 Posts
dont forget the 4oz of acdelco or equivillent limited slip additive. it will be available beside the gear oil.
Old 10-07-2015, 02:50 PM
DGXR
DGXR's Avatar
80w90 GL5 gear oil will work fine. I would be very surprised if you had any trouble using this fluid in the 4-speed portion of your 4+3 manual.
The OP is looking to fill a manual transmission, not a differential.
Old 10-07-2015, 04:23 PM
VikingTrad3r
Oil Producer
in that case op forget what i said!
Old 10-07-2015, 09:57 PM
TX-Techman
TX-Techman's Avatar
I run amsoil synthetic in everything, no worries about the additive for limited slip ... Www.amsoil.com and use the vehicle product selector
Old 10-08-2015, 12:13 AM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,017 Posts
In the Muncie and early Warner '57 - '63 in GM the GL4 was the spec I believe, in the later '74+ Warner and the 4+ the spec I believe was changed to GL5 for all Warner and the 4+, the composition of the rings was changed and GL5 created no issues. When you use the late rings in the early transmissions GL5 I believe becomes the lube of choice.
I haven't checked a '74+ lubricant guide but it might be interesting to.
It gets debated frequently and there's certainly some Internet lore involved. Try reading the C3 section from time to time, there's those that insist ATF/Dexron correct and the "lube of choice" FOR EVERYTHING ------
To What gear oil do I use?
Quick Reply: What gear oil do I use?
