1985 L98 tach filter location?
Does anyone have a picture of where the tach filter is located on a 1985 L98? My tach just started becoming very erratic. Engine runs fine at idle and at speed. Tach is jumping all over the place. All the other gauges are perfect. From what I've read, the filter should be the problem.
http://www.ebay.com/itm/1975-1991-Corvette-Tachometer-Filter-/351542448374?hash=item51d99010f6&vxp=mtr
Best way to remove it is to remove the windshield wiper motor. It's bolted to the back side of the drivers side cylinder head. It is connected to the distributor via a wire, and has another wire connected to it that goes to the ECM/Digital Dash or wherever.
All done!
Well I just replaced the tach filter on my 85 in about 45 minutes!. It works fine now. Instead of removing the valve cover, air pump or windsheild wiper motor, I just snipped the wires off of the hidden and hard to get at old filter and left it in place. No one will ever see it anyway. I grounded and bolted the new tach filter down by using one bolt on one side of the thermostat housing. There is a lot of thread showing on that bolt so I just added a new nut and washer on top of it. I then soldered the two wires and shrink tubed them. I ran the two wires through black wire tubing back to the distibuter area where the old part was. It looks like it should have been done this way from the factory! Very easy!
Is the new filter bolted down on something metal from the frame or engine block? Sounds like yours may not be grounded or the attachment clip on the distributor is not connected completely.
pretty sure that metal bracket has nothing to do with grounding. not saying someone doesn't need to mount it securely though -
This is correct. The bracket is simply a bracket, not a ground. Mine's been flopping around the bellhousing area for years unsecured and the tach has never skipped a beat.
True. The stock tach can still work without the filter. But if the circuit gets a spike, the stock digital tach may not operate. When the filter goes bad in a stock digital (early C4) display, the gauge will go nuts if the bad filter is left in place. Part of the instructions that come with the new replacement filter specify that it MUST be bolted down to ground it so it can operate (filter) as it's is designed to do. As I said it's just simple electronics. I won't take the chance of burning out the gauge cluster over a simple $30.00 part replacement.
I see the schematic. I don't understand how the unit is grounded when the bracket clamps around the nonconductive outer surface of the filter. I may very well be wrong but nonmetal surfaces don't ground and mine works after 30+ years.
that what I was originally thinking. looking at he diagram, it must be internally making a conductive path to the mounting bracket. I initially thought it was nothing but a capacitor until I looked at the wiring schematic. now, it looks like a sort of band pass filter.
The metal mounting bracket clamps around the metal jacket of the filter. One end of the filter is metal and the other end is plastic or hard rubber. Both ends have one wire coming out to complete the circuit. The ground is conducted internally. If you look at the ones being supplied now from the after market you will see how its made. The new one looks just like the orginal one, only its silver instead of black. Same exact size. If you still have the original filter working with the original early C4 digital tach and it's not grounded by its original bracket, it may have been grounded somewhere behind the dash. Or it's operating without the filter. Just watch for electrical power spikes. That can damage your digital dash from what I've read from quite a few sources.
