Stock 89 tpi - nos or procharger?
Old 10-13-2015, 02:08 PM
89CorvetteTpi
1st Gear
89CorvetteTpi's Avatar
Default Stock 89 tpi - nos or procharger?
Nos or procharger?
Whats better for all stock tuned port injection.
Old 10-13-2015, 02:21 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
Procharger! Don't have to keep refilling a bottle!
No! NOS! It cost far less money! Best bang for the buck!
Goals and budget.
Old 10-13-2015, 09:27 PM
dizwiz24
dizwiz24's Avatar
Ive done both.
The best description of nitrous is inconvenient, and inconsistenT.
I had the nx wet system with all the bells and whistles. Bottle heater, blanket, in cabin fuel and nitrous pressure gage pod.....
The problem with nitrous is you make more power on a full bottle vs anything less.
And...heres the kicker...
This is true even if you use a bottle heater to spray at the same psi each time (on the full tank vs. ex. Half tank)
Has something to do with the ratio of liquid nitrous to gaseous.
The ratio is More liquid (vs gas form nitrous) with a full tank.
This is annoying as he11. Its like if your cAr made more power on half a tank of fuel.
Also your tq comes on hard and decreases rapidly with rpm vs. a centrifugal supercharger where tq builds about right up to your redline.
Im on procharger p600b, blowerworks 8 rib conversion, meth/water inj, afr 195 comp heads, 1 7/8" headers
Its a real thrill. Wish i would have never wasted money on the nitrous system
Old 10-14-2015, 10:00 AM
Vic'89
Vic'89's Avatar
Is that on a stock bottom end short block ?
Vic
Old 10-14-2015, 11:04 AM
Orr89rocz
Orr89rocz's Avatar
I like the blower idea in the long run even tho its expensive
Only thing i would do is get the proper sized injectors and either blowerworks maf or do speed density conversion with ebl flash p4. True boost based fueling instead of an fmu
Stock fuel pump or even aftermarket 255-340 lph wont like high fuel pressure supply with an fmu
Old 10-14-2015, 01:09 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Headwork, miniram, exhaust and cam work well too.
Old 10-14-2015, 01:41 PM
MavsAK
MavsAK's Avatar
Supercharged.
Sure, Nitrous is cheap.... at first. After a few refills though, it's not so cheap anymore, and as a previous poster alluded to it's at it's best when the tank is full.
Supercharging, and boost in general is also amazing, if you do a lot of high elevation driving. Boost, loses less horse power, with changes in air density, than does a naturally aspirated engine.
That and there's nothing...and I mean nothing quite like a boosted engine.
Gotta make sure with either one, that the engine is up to handling it. Compression tests, and coolant gas contamination checks are a must at the very least to make sure the engine's healthy enough.
Old 10-14-2015, 01:53 PM
dizwiz24
dizwiz24's Avatar
Vic
Thanks for asking.
Yes, stock bottom end. Absolutely no problems if done right.
12.5 psi max boost at 6000 rpm.
520 rwhp @5900 rpm.
Also note i took advantage that afr heads come in different cc sizes, so i dropped my compr ssion to 9.7:1 by putting bigger cc heads on.
Do a compression check to make sure the motor is good before you do this.
Also need upgrade fuel system. I have 2 fuel pumps and 60 lb hr inj. Dont rely on fmu's
Talk to greg at blowerworks
The stock knock system is good at preventing damage if its not circumvented. It saved my motor once before i did a fail safe on my methanol/water system
Old 10-14-2015, 09:33 PM
Vic'89
Vic'89's Avatar
Thanks for asking.
520 rwhp @5900 rpm.
I am impressed. Seems to work well.
Any ET's ?
Vic
Old 10-15-2015, 08:00 AM
dizwiz24
dizwiz24's Avatar
Any ET's ?
Vic
It took me 3 years to work out the bugs so and then they closed down the dragstrip near me.
Ive only have 5 runs on this combo on a still new to me unfamiliar dragstrip
On a 2.2 sec 60 ft botched launch i got a 12.2 at 123 mph
Im on a 6 speed.
The finAl mph shows that theres more et in it once i get my driving straightened out.
I beg you to talk to greg at blowerworks. He knows all the workarounds for cars of our vintage (especially the ecm).
Dont dare buy a procharger kit (the procharger head unit is a great blower but the supporting pieces, brackets, intercooler are all junk). Procharger admittd once to me that they dont do any more r&d to optimize their c4 blower kits.
If you dont listen you will end up spending almost 2x to get all the bugs fixed and buy the blowerworks system anyways. Thats kind of what happened to me.
I found a cheap used procharger p600b kit. I paid $2000 for it. Pretty much the only part thats still on my car from that kit is the head unit. Everything else was upgraded with blowerworks stuff
Old 10-17-2015, 08:15 PM
l98tpi
Max G’s
Support Corvetteforum!
l98tpi's Avatar
and you could increase displacement as well. For what I have seen supercharger and turbo kits for, you could probably get a 427sbc.
To Stock 89 tpi - nos or procharger?
Quick Reply: Stock 89 tpi - nos or procharger?
