Head lamp doors
Head lamp doors
I have a stock 95 coupe. The right head lamp door sometimes does not come open. The lamp will light, but the door doesn't open. In that case I must lift the hood and turn the **** to get the light open. Is there away to make the doors stay open permanently, even with the lights off, so that I can delay fixing the door until I am motivated? After I crank the door open by hand, if I shut off the lights both doors close. Thanks for any help
just disconnect the motors. then when your up to it spend the six bucks and replace the pucks.
There's plenty of video on how to repair the headlight motor gears and pucks. It took me 8 months to get my port side working correctly, just in time for the other one to malfunction, and it's gears have already been replaced.
Rick
Rick
Thank you for your replies. I had a couple of C-3s in the past, and there were ***** under the dash that allowed you to keep the doors open without having the lights on. I know they were vacuum operated doors. In any event, the manual that came with my 95, the one from Chevrolet that fits in the glove box, says that in cold and icy weather you should keep the doors open so they don't freeze up in the down position. I thought there would be a switch some where that would allow that without the lights being on.
