finding top dead center on cyl 1 while spark plugs are out
Location: Las Vegas - Just stop perpetuating myths please.
Sorry bub, the nylon wire tie aint gonna get u within 1 degree accuracy that most owner would like to have and tune with. Using a piston stop and enough dampner marks or even a degree wheel will get u there.
Yea, the thumb over the plug hole is used by plenty of aircraft mechanics but they have all the plugs removed and can swing a big prop for a lever arm to verify their results as many times as required. U aint gonna turn over an auto V8 enough by hand to use that.
You missed the whole point, here. #1 could be back at the rear differential for all I care.. the point here is you need to stop the #1 Piston before it can make it's full travel, in order to Validate the Harmonic Ballencer timing Marks..
Just don't get confused with number one / number two cylinders was my ONLY point
