Edelbrock 3860 or 3861??
I have an early 86 coupe. I have been searching for the difference between the two manifolds. The only thing I found out (I think) is the 3860 is for early iron heads only. The 3861 is machined to fit both angled intake bolts to the head. Does this mean I can use either manifolds on my iron head early 86?
thanks for any info......
The site I checked says the 3860 will fit the 85-91 Corvette...The 3860 I have has the 4 inner bolt holes reamed out so you can bolt either straight or at an angle, depending on which heads you have.....WW
