700R TCC Solenoid Amp?
Old 12-11-2015, 09:26 PM
91blkvette
91blkvette's Avatar
Default 700R TCC Solenoid Amp?
What amperage does the TCC Solenoid draw? Want to wire a MS3X to control the 700R, and need to confirm if a relay is required (or not)..
Old 12-11-2015, 11:47 PM
Cliff Harris
Cliff Harris's Avatar
The stock ECM does not use a relay to drive the TCC solenoid, so I doubt that one is needed. It does use a quad driver, so take that into consideration.
This link says the quad driver is rated at 1 amp per channel, so it's not a super heavy duty part:
http://www.ti.com/product/TPIC2404/technicaldocuments
91blkvette (12-12-2015)
Old 12-12-2015, 09:37 PM
91blkvette
91blkvette's Avatar
That 1amp value is what I needed to know. Anything over 3 amps requires a relay for the MS3.
Thanks.
To 700R TCC Solenoid Amp?
Quick Reply: 700R TCC Solenoid Amp?
