Tpi cranks no sign of starting
Recently tore my carb setup off my 86 vette to go back stock with tpi setup. Motor all together I get good spark everything seems fine, motor spins but I'm not even getting a putter out of it with spraying ether. The tpi is off a 87 iroc 305 is this part of my problem?
Did you check fuel pressure yet? What about putting a noid light and see if the injectors are pulsing?
If it wont hit on ether I would recheck static timing or make sure rotor is pointing on #1 when balancer is at 0 TDC. Possibly distributor is 180 out. recheck firing order. If it has spark and timing is close it should hit or possibly run until spray is gone. After that point you need to verify fuel injection component operation. If you changed out in tank fuel pump (5-9 psi)when you went to carb. Fuel pump won't develop the 30+ psi for injectors to operate correctly and engine to start.
I used a Holley regulator to bring psi down. Removed it when I replaced the intake. The fuel pump is in the tank. Also I tried dropping distributor 180 out an still no fire. I will recheck my plug wires. What sensors might stop me from firing?
If you have spark ... pick up coil and ignition coil should be good. When you spray flammable fluid if the is spark at the right time and compression, it should hit with out sensors. Sensors that effect starting coolant, MAF, MAP main ones. Does amber check engine light work? Need to check fuel pressure over 36 psi. Injectors should have 12v to them and if you have "noid" light should blink as engine is cranked. check all of them. There are fuses that feed injectors. There is also a "cold start injector" only works when engine is cold not after it warms up. You can use test light to test for injector pulse. Attach clamp to battery positive and probe to ground side of injector connector. There is a purple wire in 4 wire connector for ecm-distributor connector. If you touch test light (clamp on positive battery post) to the purple wire terminal on ecm side of connector you should hear injectors cycle. If not you may have bad or missing ecm. I believe the 305 injectors are "smaller" than the 350s so you still may have drivability issues. Did you change it to carb or was it car when you got it. You really Need a Factory Service Manual to sort this out. Pages would be better PC require a lot of walking.
Power to all injectors even cold start, power to dist. I used this dist when I ran the carb setup but I rechecked it anyway. Hadn't checked for tdc again but I'll have to wait an check it later. Wife said I gotta stop for tonight. Lol tnx so far to all is there anything else I might be missing? I do have another tpi setup from a 350 with no cold start an has a map sensor. How can I check the injectors to see if there gummed up? Might swap them in
Down from what? What is it at now? Will it hold pressure and for how long?
You have quite a mess. I wouldn't be in a hurry. Just follow the flow charts and realize you may have some incorrect parts. You need to go to dealer and get a few terminals that fit ecm connectors so you can "Pin Test" circuits. Using paper clips and stabbing wires can lead to other problems. You do need to make sure you have the correct distributor. Most carb conversions will include installing a mechanical/vacuum advance distributor. The computer distributor has no advance because the ecm provides it. Good Luck
I'd gue$$ you're about to gue$$ away a lot of money, unle$$ you figure out what'$ wrong, fir$t! Do you have the FSM for your car? Absolute necessity!
Is your manual the GM FSM, or a worthless Chilton or Haynes?
I've got a chiltons. I think I'm at a stale mate right the moment, I've gotta get some money together to buy a fuel pressure tester mine broke. Well the motor I tore the intake off supposedly had 60,000 on it an sat for 15 yrs
Tnx when I got the car the motor was just sitting in there unhooked I hooked it up an used the ECM for the most part an tucked the rest of the wires drove it around the block an decided to go back tpi. I don't think I'm having problems with wires or ECM I think it's in this old set ups 20 yrs old.I'm gonna venture to geuss I need to buy new injectors an sensors
Until you know what is wrong and thus which sensor, all you are doing is compounding the problem.
You need a scanner and an FSM. In a pinch, you might be able to borrow one from an Autozone along with tools like a fuel pressure tester, compression tester, etc, etc.
The injectors probably have varnish and would need to be cleaned. My ATVs, Jetskis and Vette injectors are sent off every 3 years for cleaning and testing. Daily drivers are sent off every 100K since it doesn't sit as long. Never had the injectors come back with a perfect "before" and similar "after".
See if your local Autozone can lend you a fuel pressure tester.
