Are these spark plugs good to use?
Hello everyone, I just finished installing my NOS wet plate kit in my 1985 Corvette. I am going to run a 100 shot and I just installed these spark plugs: http://www.summitracing.com/parts/ngk-5122
The engine made 344 rwhp and 343 rwtq with 10:1 compression.
The modifications are as follows:
TPIS Miniram, TPIS flat tappet cam (224*/224* @ 0.050", 0.528"/0.528" total valve lift with 1.6 roller rockers, 112* LSA), 58 mm throttle body, AFR 195 Eliminator heads, MSD 6AL2 ignition box + MSD timing control box, 1.6 comp cams roller rockers, 1 3/4" long tube hooker headers, 2 1/2" true dual Corsa exhaust
Do you think the spark plugs in that link are suitable for my engine on a 100 shot, specifically the heat range?
Thank you.
Thank you.
