Don't know on your 88, but on my 92, the fuses for the door locks are in a separate fuse panel tucked up under the plastic on the underside of the dash on the passenger side. Kind of above where the passengers feet would be, couple of screws to remove...and then you'll spot the auxilary fuse panel. Don't have a clue as to why they put it there.
