The quest for power.
Old 02-01-2016, 08:53 PM
95wht6spd
95wht6spd's Avatar
Consider relocating battery to rear storage container?
DRM brake bias spring is a worthwhile $20.
Old 02-01-2016, 09:37 PM
383tpimachine
383tpimachine's Avatar
Have but would have to be exposed. I still have a full soundsystem with a huge amp and two 10's.
Have it. Once I figure out brake route I will get either a wilwood setup or hydroboost. So after some miles
Old 02-21-2016, 05:06 PM
383tpimachine
Well another trip another round of progress.
First started by disassembling the rear spindles. Man they were nasty. 100k miles of grime an a blown ujoint caked up.
Soaking
and pressure blasted. Next they are getting powdercoated like everything else. Have new wheel bearings going in.
Next I moved onto making AN fuel lines. This was a MAJOR pain in the ***. Turns out Redhorse fittings that are turns (45*, 90*, 120*) are SLIGHTLY larger than the actual AN size. This means the wrenches will not fit. Had to improvise with a few other wrenches.
10AN feed from tank to pump to split.
Split goes from 10AN to dual 6AN. Each rail is fed then looped back to each side of the regulator. Single 6AN return.
Wrapped and installed my headers with DEI titanium wrap.
Then worked on the Charge pipe.
Rough fit
Little more trimming or boot and pipe and drilled the holes for the meth injection. It goes off for powdercoating aswell.
Old 02-24-2016, 08:08 PM
dgantt
dgantt's Avatar
Dude, everything looks amazing! Great job!
Old 03-12-2016, 08:37 PM
383tpimachine
I am getting close enough to make me get stir crazy.
Started by unwrapping a few pretty pieces.
Spindles coated and sexy.
Installed the bearings.
Rear brakes came in. Waiting on fronts.
Next I moved onto this beauty. StreetShop Hammerhead 12 bolt pumpkin. Tru Trac 3.42 gears 33 spline. Uses D44 batwing and c beam. Getting a driveshaft made up.
Painted.
Assembled.
All bolted in.
Intercooler back from powdercoat and paint. Mocked up for Meth line lengths.
Old 03-13-2016, 09:31 AM
blackozvet
blackozvet's Avatar
your taking on a lot at once, keep up the good work !
Old 03-13-2016, 08:46 PM
383tpimachine
Do it once right?
Only things I am leaving on the table is a Hogan intake, stronger stub axles, and hydroboost brakes.
Intake is waiting to see how my HSR performs, stub axles I am looking for and may buy before this is all done, and hydroboost depends on brake issues coming out of boost.
Old 03-13-2016, 11:33 PM
blackozvet
blackozvet's Avatar
Originally Posted by 383tpimachine
Do it once right?
Im still in therapy after the last modification I did !
do you really need a Hogan when its boosted ?
Old 03-14-2016, 08:27 PM
383tpimachine
Every little bit can help. I would like slightly longer runner to optimize the powerband from 4000-6500rpm. Plus they are sexy.
Old 03-15-2016, 05:55 AM
blackozvet
blackozvet's Avatar
I not sure whats so sexy about this ?
Old 03-15-2016, 02:13 PM
383tpimachine
Stub axles from summerbrothers are a go. 27spline to 31 spline. Dennys driveshaft and halfshafts ordered. Just money right?
Old 03-18-2016, 09:01 PM
ghoastrider1
ghoastrider1's Avatar
Heck of a build. love it.
Old 03-22-2016, 05:24 PM
  #33
95wht6spd
95wht6spd's Avatar
Any updates?
Old 03-22-2016, 06:14 PM
  #34
DanielRicany
DanielRicany's Avatar
You weren't kidding when you said "quest for power"... wow!
Old 03-22-2016, 09:59 PM
  #35
383tpimachine
Any updates?
Yes and no. Decided to scrap the whole stock rad mount setup and am going custom aluminum.
Trans yoke sent off to Dennys DS to make my custom driveshafts and halfshafts.
Stub axles and spindle/bearings sent to summers brothers for their 31 spline treatment.
Ordered my meth lines. Thanks Julio for all the help at Alkycontrol.
Ordered a few more pieces from summit to make everything work well.
Flexplate sent back and correct one ordered for Mcleod Twin Disk.
Next trip will be all about wiring and final mounting of the IC, piping, and radiator.
Just the common 400rwhp goal.....@3500rpm.
Old 03-22-2016, 11:00 PM
  #36
1993C4LT1
1993C4LT1's Avatar
Damn!
Old 03-22-2016, 11:26 PM
  #37
95wht6spd
95wht6spd's Avatar
Custom rad or just mount?
Will stock hood close the way it is?
To The quest for power.
Old 03-23-2016, 01:24 AM
  #38
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Nice build
Old 03-23-2016, 10:45 PM
  #39
383tpimachine
Big dewitts from a few years ago custom mounted for clearance.
No idea on hood. While it should it may be very close to the charge pipe. By measure I will have 1/2 inch but never know until it is mounted.
Regardless I will not be using a stock hood.
Old 03-30-2016, 11:01 PM
  #40
Jonnymac
Jonnymac's Avatar
St. Jude Donor '08
Great work. Can’t take it with you so might as will have fun.
Quick Reply: The quest for power.
