93 LT1, IAC Counts at 0
Yes, my IAC counts are at zero. Which means there is a vacuum leak right? Well if there is, I can't find it. I've replaced bad ones already. The 2 way check valve, and two others that go to throttle body. With AC on, IAC counts are at 20. Gas mileage isn't great in the city. Getting 11-12 city, and this is with nornal driving. Used to be at 8, but that was due to a toasted exhaust manifold gasket. Left bank still lean. Highest I've seen was the left BLM at 143(new o2's). No codes.
So I guess my question is, what are common vacuum leaks I need to look for?
Otherwise, car runs great, good acceleration. Idle is pretty good. Used to be horrible.
And yes, car does go into closed loop. It has many new parts.
get a cheap cigar and blow heavy smoke in the hose that goes to the brake booster in to the engin and see where it comes out. blow a bit into the booster too. does your cruise control work?
1993C4LT1 (02-02-2016)
Sweet! I was gonna ask where the smoke had to be blown into. That brake booster hose goes into the intake and the booster, of course. Does it matter which end of the hose the smoke gets blown into? Will have to ask my neighbor, as I don't smoke
Antfarmer, you help a lot of us out, and I appreciate that.
Oh, and does the engine have to be running while doing the smoke test?
antfarmer2 (02-03-2016)
If RPM isn't above normal idle you may not have a vacuum leak at all. You're car might be perfectly fine if all feels good. Track MPG by hand not by the computer.
How do the brakes feel? Does your idle surge? Have you confirmed EGR is okay?
Oh yea, idle is good. It's cold here in Dallas. On cold start, it goes up to aboit 1,500 rpm amd comes down to about 700 in 30 seconds. Warm idle is like 600 or 650. I have a friend with a 95, that car idles smoother than mine. But 93 is batch fire injection. Brakes feel good, pedal isn't hard. How do I confirm that the EGR is OK? No idle surge.
looks like it is cocked cut a clean edge and try again.
What do you mean by integrator? The picture above was the only leaking line. Still seems really high of a BLM, for just that little leak.
I agree its adding fuel in the long term and that is a small leak indeed. That is why I asked about the integrator. That is short term fuel trim. What is it doing?
http://www.gnttype.org/techarea/faq/BLMINT.html
give it another blow of smoke. how old are your o2's and make sure the wires are not melted.
What does TPS read and what happens it you try to block out air to throttle body does it stall? Just thinking you need to check some of the basics min air and tps settings.
