Rear tires look bowed on 1996
How do you know they are not any good?
Yes, it affects the repair because it won't HOLD alignment if they are loose.
Yep, I need all new ball joints, both upper and lower, and I probably should have the bushings redone as well.
The back could probably use the same treatment. :P
It's an ongoing project. I got the alignment because I had new tires and all new outer tie rods put on and it was way off.
If the car "looks" like the rear end have neg camber - I would suggest the following ... Borrow a digital level (Sears has them, and most home improvement stores have them.) Verify the digital level is calibrated by making sure it reads a home door jam equally when the level is vertical and when it's upside down.
Now, with the car parked on level ground, measure the (vertical) angle of the two rear tires by placing the level against the flat of the wheel or by using equal width spacers on the "wheel lip" (the flat that the tire bead seals against) - what you have to do depends on how long your level is. Each side should be about 90 degrees. A slight amount (say 0.3 degrees) off - with the top of the tires closer to each other is acceptable. If not right - get the car re-aligned. If it is right - and you still think the cars tires are leaning - see an optometrist.
Doing any alignment with worn suspension parts is a waste of time - the readings won't be accurate, and the work will need to be redone. I get redoing toe-in after replacing a tie rod end - but doing a 4 wheel alignment at that time was probably not in your best interest.
You can get a free app for your phone and a stick.
Another thing to check is if the Spindle Rod Adjustment Nut has backed off. The torque spec on it is 187 ft-lbs which is stout. If it backs off, you will lose camber control.
Thanks guys. I have so much to do with this car and it's taking awhile.
Here's whats on my list:
fuel filter
pcv valve
ball joints
stainless brake lines
bushings
find oil leaks
fix tranny leak near driveshaft
remove radiator shroud and clean radiator debris
install tranny cooler
I have two little ones that demand a lot of my time and so I have to do things little by little. :P
fuel filter
pcv valve
ball joints
bushings
find oil leaks
