wtf baked my valve covers have blisters
Oil Producer
well in my 85 refresh i thought id do my valve covers.
wtf did i do wrong.
what is the typical reason for this.
wtf did i do wrong.
Oil Producer
baked at 200 deg.
its funny cause im fairly certain the previous owner tried to do it and there were blisters on them.
now i did it.
im thinking i had trapped gas in the paint from putting layers on too far apart.
now i did it.
Or oil from the start.
Oil Producer
i used some really strong solvent on them....
im going to try and sand off the blisters, put them in the dishwasher, and then repaint. no way im going to totally strip them again.
Oil Producer
hope you're not "baking" those things in your wife's kitchen stove/oven - . why do you feel you need to do that?
Oil Producer
so, am I to understand, if you paint your whole engine, you need to bake it? . seriously, I've used duplicolor engine enamel, on my 85 - didn't bake anything, in fact, nowhere on the can does it say anything about baking. ???
Oil Producer
Oil Producer
yah i contemplated doing the shine but wanted stock look.
i took my mouse sander to the blisters and then stuck in bbq again.
wasnt so bad with mouse sander.
ill be hitting them again with more enamel and rebaking.
interesting interpretation of instructions.
ill email dup and get thier comments.
thnx.
thnx.
These valve cover are always hard to paint. Mine are chipping now and peeling I keep having to touch them up. They sure looked good when they were freshly painted. I'm going to end up buying new valve covers probably.
Oil Producer
do we have any idea what makes them so hard to paint vs other ones?
they look amazing so far! if i can get them to heat cycle up to 300f without blistering i think im good to go.
the paint that did not blister on mine (most of it) was hard to get off with sand paper so i think im close.
im stoked to get a system down to refurb them for the cost of one pint can and a lazy sunday morning.
Did you do a pre bake to bake out trapped solvents/oils?
My bad, I just saw that you didn't. The heat paints are more durable due to the amount of ceramics in them. I'd just sand and respray and call it a day.
If it was me, I agree cooking the part first to force out any residual contaminants first. Let it cool to room temp and only then spray it. Let it air dry for several days and only then if the direction say to heat it would I attempt to cook the finish. Based on the photo, it does not appear to be mandatory so personally I would only let it air dry for that week and then mount them up to the engine.
My 2 cents.
I think you're on the right track. I did spraying of furniture for years and used many different types of finishes. Problem developed if the finish skimmed prior to all the solvent gassing out. It acted like plastic wrap, forming a seal against the finish preventing the ability of the solvent from exiting, forming pockets and boils in the finish.
My 2 cents.
My 2 cents.
I refinished my 90's VC (satin nickel and topcoat only) it's been about two years now, no issues. I did refinish my 85's - bead blasted down to base, chemical clean, etch primer, several coats of texture, and topcoat. have yet to fire the engine though...
