1988 Idles But Dies When Given Throttle
5th Gear
Hello everyone,
I have a stock 1988 convertible that is giving me some trouble. Let me first say that the car sat for approximately 8-9 months since I have driven it (I had to move away for classes) with a known issue. The car would fire up, run for a few seconds, and then die out. I am just now getting to diagnosing the problem. Thinking the problem was fuel related, I tested the fuel pressure at the schrader valve on the fuel rail. When switching the car to the on position but not cranking, I can hear the pump turn on and there is fuel at the test valve. The pressure gauge will read 8 PSI when the pump is priming and then drop to 0 PSI as soon as the pump stops running. After starting the engine, the pressure once again goes to 8 PSI and holds steady. The engine will start fairly easily and idle indefinitely with the MAF sensor unplugged (which I believe puts the car into "limp home mode" by maxing out the fuel system), but as soon as you give it any throttle, it will die instantly. I suspect that I have a bad fuel pump due to the lack of sufficient pressure, but I wonder about the instant loss of pressure. Could I also have a bad pressure regulator? I'm not sure where to go from here, I have a fuel filter on the way already but don't want to throw money at problems I may or may not have!
Thanks in advance, I'm kind of getting crazy over here!
Pull the vacumme line off the fpr and smell for fuel. And could be a bad pulsater off the fuel pump. It can be replaced with a piece of proper hose that can be submerged. Could also be leaky injectors.
5th Gear
Thanks for the quick reply!
I pulled the vacuum line off the pressure regulator and noticed a slight fuel smell, but no fuel seems to be inside the line. I suppose the fuel smell could indicate a leaky diaphragm inside the FPR? Also, is there any way to test for a bad pulsater without pulling the sending unit?
5th Gear
I just finished the fuel filter replacement.
A lot of crud came out of the old filter so I was hopeful at first, but now I read no pressure at the fuel rail. So I think it is safe to assume I have a bad fuel pump now. I did start the car with the mass airflow sensor plugged in and it ran for longer than it would before, so I'm sure the filter helped, but its looking like I am placing a fuel pump order sometime in the near future.
No trips to the hardware store for anything besides your normal hand tools and bolts are all replaced.
5th Gear
Fixed!
It turns out that the short rubber hose that connects the fuel pump to the sending unit had completely disentigrated and would not hold any pressure at all. Put the new pump in anyway and repaired the line, and she fired right up and responds to throttle now! Now on to fixing the idle (I moved the TPS when diagnosing the problem, so now I've got to reset the idle speed), give it an oil change, and get back on the road!
Thanks for the help, guys! It sure feels good to move on from this!
Fixed!
You don't have to reset min idle if it is just TPS. OTOH, it is a good idea to take the TB out, remove the IAC, remove the housing, clean the crud out of it, reassemble with NEW GASKETS, check timing, use scanner to set minimum idle and then TPS. I'd do 20 counts for IAC with engine at stable operating temp and everything but motor off.
You NEED SAE 30R10 hose. It is designed for the in-tank environment. Also due to the pressure I recommend using actual fuel injection hose clamps NOT worn drive clamps.
You can do it right or do it half assed, your choice, your car.
http://www.racetronix.biz/itemdesc.a...IK-006&eq=&Tp=
I'd send email to them but I believe this is the kit required. Comes with new bolts and hose and gasket.
Fixed!
Good job
