VBP Advanced Street alignment specs on a lowered C-4...anyone?
Old 09-02-2002, 06:48 PM
Hardcorvette
Hardcorvette's Avatar
St. Jude Donor '06-'07-'08-'09-'10
Default VBP Advanced Street alignment specs on a lowered C-4...anyone?
VBP Advanced Street alignment specs on a lowered C-4...anyone running this set-up? I'm expecting my lowering kit from VBP in a few days, I should have it installed shortly thereafter. Has anyone with a lowered C-4 used the VBP Advanced Street alignment specs? Is there any abnormal tire wear associated with this set-up? Has the handling/cornering improved at all? Any thoughts or suggestions? TIA :cheers: Mike
Old 09-02-2002, 10:16 PM
Hardcorvette
Default Re: VBP Advanced Street alignment specs on a lowered C-4...anyone? (Hardcorvette)
^^^ :chevy
Old 09-03-2002, 02:02 PM
merrick
merrick's Avatar
No I haven't, but what's their specs?
Old 09-03-2002, 07:14 PM
1991Z07
1991Z07's Avatar
I can't remember the advanced street specs, but I run mine at zero toe F/R, -3/4" camber F/R & maximum caster.
I have about 10k on the new tires and they are wearing just fine.
I am slammed as far down as it goes...
Old 09-03-2002, 08:31 PM
Hardcorvette
Default Re: VBP Advanced Street alignment specs on a lowered C-4...anyone? (merrick)
VBP Advanced Street specs;
Front
0" Toe
1/4 deg. neg. Camber
5-7 deg. pos. Caster
Back
1/8" Toe
1/2 deg. neg. Camber
Thanks for your specs Joe90! I'm sure it handles as good as it looks! :cheers:
[Modified by Hardcorvette, 7:34 PM 9/3/2002]
To VBP Advanced Street alignment specs on a lowered C-4...anyone?
Quick Reply: VBP Advanced Street alignment specs on a lowered C-4...anyone?
