Parallel Plumb Fittings & Adapters - Help!
Trying to come up with a parts list to prepare for parallel plumbing and an external regulator for my '84 CFI. Got the regulator/accumulator block-offs covered. Think I've got the routing set, but correct me if I'm wrong:
-Remove all connections. Reroute the stock supply line to the Y-block inlet.
-Run two supply lines (one per TB) from the Y-block outlets to the throttle body inlets.
-Run two return lines (one per TB) from the throttle body outlets to the regulator inlets.
-Connect the regulator outlet to the factory return line.
Simple, right? Now for the trouble. I'm having a hard time finding the right adapter bits to make it all mate up. Here's what I know:
-OEM supply and return lines are 3/8" and 5/16" OD, respectively. They use 5/8-18 and 1/2-20 inverted flare fittings, respectively. I'd like to reuse these & avoid the cost of a flaring kit.
-The Aeromotive 13301 regulator (on-hand) has 3/8 NPT ports all around.
-I can get a Y-block that also has 3/8 NPT ports, or one that accepts -AN fittings.
-I'd love to find a Y-block with 9/16-18 inverted flare inlet port so I could mate it directly to the OEM supply line, but haven't seen any. Next best thing would be a 9/16-18 inverted female to 3/8 NPT male adapter...but also no joy.
-I have also been unsuccessful locating a 3/8 NPT male to 1/2-20 inverted female adapter for the "regulator to OEM return line" connection. Found a part number at https://www.fastenal.com/products/details/440291-131280 ...but they are out-of-stock everywhere.
Is there an easier way? Am I missing the point? I really didn't expect adapter fitting nonsense to hold me back this much, but I must admit trying to convert back and forth between -AN, inverted flare, and NPT is really bringing out my dumb.
Has anyone who has done this project successfully retained the stock lines & fittings, or is it an exercise in futility? Input welcome...school me on fuel plumbing!
have you checked Summit, they have a pretty big range of fittings and adaptors, I bought all my stuff from them to do my single plane conversion.
http://www.summitracing.com/int/sear...illocation=int
You do know that the stock injectors are two different sizes as a result of the stock system having series (not parallel) piping and a fuel pressure drop between the front & rear TBIs, right? So on top of the piping issues you need matched injectors also.
Finally got it figured! Decided to go with -6AN lines & Y-block. Part list with locations:
- [eBay] [TBI regulator block-off plates & gaskets] [x2] (one set per TB)
- [eBay] [80# big block injectors] [x2] (to replace OEM stagger-sized pair)
- [Aeromotive 13301] [Vaccum referenced fuel pressure regulator] [x1] (return side)
- [Russell 650400] [Y-block] [x1] (supply side)
- [Marshall MS00060] [0-60 PSI fuel gage] [x1] (connected to regulator)
- [Russell 661571] [3/8 to 1/8 NPT reducer] [x1] (connects gage to regulator outlet)
- [eBay] [-6AN male/male coupler] [x2] (Y-block outlets)
- [Russell 640610] [-6AN male to 5/8-18 inverted female] [x1] (OEM supply line to Y-block adapter)
- [Russell 640380] [-6AN male to 5/8-18 inverted male] [x4] (TB adapters)
- [Russell 660461] [-6AN male to 3/8 NPT male] [x3] (2x regulator inlets, 1x connected to return adapter)
- [Russell 640600] [-6AN male to 1/2-20 inverted female] [x1] (-6AN to OEM return line adapter)
- [Russell 640001] [-6AN female/female coupler] [x1] (connecting 660461 & 640600)
- [eBay] [3/8 NPT pipe plug] [x1] (extra regulator port)
Includes everything except the hose & ends; will have to mock this all up before I'll know the total length required. Throwing new RHS aluminum heads into the mix; replacement injectors are sized accordingly.
For anyone else considering this project, I did already pick up an extra set of OEM TB fittings:
I plan to swap out the one smaller return fitting on my car and end up with all the same size (M12 x 1.25 to 5/8-18 inverted). Check your shopping list! Corvettenorway's link shows you can remove those OEM conversion fittings entirely and use metric to -AN carb inlet fittings instead...probably easier, but I couldn't find any which would match the rest of my silver-colored fittings
Yep...hence why I'm going to all this trouble to correct that!
other than the renegarde,any engine mods ??
Big project in the works. Aside from intake mani swap, just exhaust is done; 3" true dual w/cutouts & OEM mufflers. Slightly upsized radiator from Champion as well.
In the process of adding RHS 180cc/64cc heads, new valvetrain, parallel plumb w/upsized injectors & vaccum referenced regulator, EBL flash ECM, and wideband O2.
Cam/lifter kit & porting will come after I get her running & stable
sounds like fun and love to se som dyno result
Minor update. Swapped out the 650400 female y-block (which would have required o-ring fittings to seal) for a 650430 male one. Returned the 2x eBay -6AN male-to-male unions I thought I'd need for the y-block outlets. Purchased an additional 640001 -6AN female-to-female union so the now-male y-block inlet will mate with the 640610 -6AN male to 5/8-18 inverted female inlet adapter.
Another update--swapped out MS00060 for MS00030 0-30 PSI gage. I should have done fuel requirement calcs before ordering! Will be running <30 PSI fuel pressure for the foreseeable future (probably ~25), so I may as well have proper resolution
