Which steering wheel puller ?
Old 03-19-2016, 03:20 PM
ChrisWhewell
ChrisWhewell's Avatar
Default Which steering wheel puller ?
Hey ya all, I'm thinking I might need to pull my steering wheel, turn signal switch potential issue. Can anyone recommend which puller I should get, for my '93 ? Thanks alot
Old 03-19-2016, 03:31 PM
THE 383 admiral
THE 383 admiral's Avatar
2 bolt slotted compact puller along with a lock plate ring compreesor.
Similar to these.
Old 03-19-2016, 03:32 PM
THE 383 admiral
Old 03-19-2016, 05:26 PM
ChrisWhewell
Thanks guys, I didn't want to get the wrong one. You've really helped. Have a great weekend
Old 03-19-2016, 09:09 PM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
Both should likely be available as "loaner" from the local auto chain BUT your concern needs to be the 2-bolts for the puller. The loaner is usually missing some or there are incorrect ones in the kit.
I believe that the C4 wheel uses 5/16-18 - I seem to recall someone arguing some Metric spec but I'm pretty sure the 5/16-18 is correct. Try them before you start and "force nothing". 4" long maybe. Post back the size you actually use so if someone stumbles across the thread needing later.
I've done a couple in the past that actually just needed a "jerk".
What does the car do? There's considerable aggravation for a novice in the column if there's no need to go there to start.
Old 03-20-2016, 08:25 AM
ChrisWhewell
This
https://www.corvetteforum.com/forums...rn-signal.html
I've been driving during daylight only and using my arm to signal right-hand turns
Old 03-20-2016, 08:45 AM
ricasso
ricasso's Avatar
Took mine off my 94 a couple of months ago, it just pulled off, no need for a puller, my advice would be try it first before spending money on a tool you dont need.
Old 03-20-2016, 07:05 PM
THE 383 admiral
I have yet to find a wheel. To simply tug. And pops off.
The c4 family still has Good ole SAE 5/16 -18 for the steering wheel bolts.
Old 03-21-2016, 01:10 AM
Cliff Harris
Cliff Harris's Avatar
I tried yanking on the steering wheel but it wouldn't come off. I used a harmonic balancer puller to get it off.
Old 03-21-2016, 03:05 PM
ChrisWhewell
.....I've done a couple in the past that actually just needed a "jerk"......
I wish. With my luck, I'll probably have to douse mine with PB blaster for a month, lol
Old 03-25-2016, 12:22 PM
bxtech
bxtech's Avatar
I haven't used a puller in years now. Using a brass rod turned down to about a little less than 1/2" on one end, I use it as a punch. I put the steering wheel nut on a few threads to prevent the rod from slipping off center, put the end of the brass rod in the center of the steering shaft, have one person sit in the driver's seat pulling hard on the steering wheel and slightly rocking it from side to side while the other person gives the brass rod a hard whack with a hammer. You can lube the connection beforehand with PB Blaster or similar like ChrisWhewell mentioned as it can only help. The nut on the end of the steering shaft a few threads will also keep the wheel from flying off into someone's face when it breaks free.
Ever since someone showed me this trick, it has worked every time. BTW, don't forget to mark the alignment of the steering wheel on the shaft before removal. Easy to forget so that you can reinstall it exactly as removed. Good luck.
To Which steering wheel puller ?
Quick Reply: Which steering wheel puller ?
