Grinding, popping rear driver side tire
Old 04-29-2016, 07:49 PM
antfarmer2
antfarmer2's Avatar
Originally Posted by .50ae
Should be. Didn't see anything wrong with them when I replaced the pads and rotors about 100 miles ago. Going to see if I can possibly get a video (warning: it's going to be a crappy phone video)
Is that when the noise started that might have been some good info. A friend put a pad in backwards before. Still brings a tear to my eye and have not let him forget it yet.
Old 04-29-2016, 08:10 PM
.50ae
.50ae's Avatar
Noise started awhile ago. Made a squeaking sound at first so I replaced the bearing. It still made the same noise after I did that but I kind of just ignored it. Made the noise at slow speed reverse and forward. Started making a grinding popping noise so I replaced the pads and rotor. Now it's like this. Sorry for the angle. Hard to video while watching the road. Only happens when accelerating and only at more than 1/4 throttle.
Old 04-29-2016, 08:25 PM
antfarmer2
antfarmer2's Avatar
I seem not to be able to see some videos in here. Did you feel the ujoints?
Old 04-29-2016, 08:27 PM
.50ae
.50ae's Avatar
Here's the link
Old 04-29-2016, 08:32 PM
antfarmer2
antfarmer2's Avatar
Did you roll your tire around when it was off? And lub your calipers
Old 04-29-2016, 08:37 PM
.50ae
.50ae's Avatar
Like roll it around by itself? Not really I rolled it about 2 feet to get it out if the way and then I laid it down. Where should I lube them?
Old 04-29-2016, 09:17 PM
VikingTrad3r
Oil Producer
Support Corvetteforum!
VikingTrad3r's Avatar
Received 2,261 Likes on 1,446 Posts
can you block the front wheels, jack the backend, USE MULTIPLE JACKSTANDS, and get under there and rotate the wheels?
it sounds a *bit* like my inner u joint that went. sounds real loud.
given that u just did the hub work, and greased it, id be looking for other things. soundsike something large and visible hitting something if u could get under. if u dont hear anything with it jacked think about the suspension being loaded and u should see SOMEthing showing wear marks. parking break cable?? is it out of the holding bracket?
Old 04-29-2016, 10:07 PM
.50ae
.50ae's Avatar
Took your advice and jacked it up on both sides and turned the wheels and it is definitely the u joint. It's weird because it didn't move at all before. It's this here:
Moves like a sob. Is this an easy job? Also can I keep driving it like this until I get it fixed?
Old 04-30-2016, 01:26 AM
VikingTrad3r
Oil Producer
great. not hard. mark camber bolts good. u joint strap bits give bit of trouble. 8mm i think. jack up safe and good to go. will need to rotate tires to bring other side of ubolt straps. post with questions.
Old 04-30-2016, 11:40 AM
antfarmer2
antfarmer2's Avatar
I would not drive it could cause a lot more damage.
Old 04-30-2016, 12:09 PM
hcbph
hcbph's Avatar
It's not hard to change them. Here's an excellent thread that goes through it, just go through the point of pulling the axels: http://www.digitalcorvettes.com/foru...d.php?t=144562
Additionally, I'm a bit of a nervous Nelly when it comes to pressing the old joints out and having aluminum half shafts. I have a hydraulic press and made up a tool that allows you to press against only one side of the U-joint at one time, reducing the chance of bending anything.
Hope that helps.
Old 04-30-2016, 03:41 PM
.50ae
.50ae's Avatar
Ok so I go out to start working on the car and the half shaft doesn't move anymore.
Old 04-30-2016, 03:56 PM
  #33
Michael Hunter
Michael Hunter's Avatar
I had the same noise coming from the back and it was stabilizer bushings. Good Luck!
Old 04-30-2016, 04:01 PM
  #34
VikingTrad3r
Oil Producer
just fyi, you can borrow a busing press from autozone you dont need a shop press.
Hope that helps.
Old 04-30-2016, 04:04 PM
  #35
.50ae
.50ae's Avatar
I have a vise I'm planning on using but we'll see.
Old 04-30-2016, 04:30 PM
  #36
.50ae
.50ae's Avatar
Having some trouble with the tie rod end and the lower control arm. Removed the outer bolt on the control arm. Should I loosen the inner bolt too? Trying to avoid doing that so I don't mess up the camber. Also I took out the nut on the tie rod end. Seems stuck. Do I just hit it until it comes out?
Old 04-30-2016, 05:27 PM
  #37
.50ae
.50ae's Avatar
Got the lca out of the way but this mother f***ing tie rod will not come out. Tried heat wd 40 and hammering every possible angle. Anyone got a trick?
To Grinding, popping rear driver side tire
Old 04-30-2016, 05:41 PM
  #38
antfarmer2
antfarmer2's Avatar
What part of the tie rod? If it is on the hub back the nut off and hit it or get a pickle fork.
Old 04-30-2016, 05:45 PM
  #39
.50ae
.50ae's Avatar
The outer part in the knuckle
Old 04-30-2016, 06:03 PM
  #40
antfarmer2
antfarmer2's Avatar
parts store will loan a fork. Block it good to keep it from bouncing.
Quick Reply: Grinding, popping rear driver side tire
