Belt tensioner and pulley torque spec
Christi@n (04-26-2016)
From my '92 FSM, the bolts for both the Drive Belt Tensioner and the Drive Belt Idler Pulley are torqued to 24 ft-lbs or 33 Newton-meters.
Your '95 should not be a lot different, if at all.
"Laser alignment tool" ?? Nothing in my FSM that talks about that. Where did you see or hear anything about such a tool?
Christi@n (06-09-2017)
Usually before to make a work on my vette that sounds as "new" or never done before, i like to take informations about it via web, Actually there are a lot of videos on youtube that speak about laser alignment tool, in order to get a perfect pulley alignment.
Sorry, didn't mean to come off as a smart A$$. The only need for something like this in my opinion would be for a custom type setup i.e mixed pulleys for non-OEM or moved locations of accessories.
