1986 runs rough
1986 runs rough
Any help? 86 runs rough. Runs like it has a miss. Seems like cylinders 1&2 aren't firing. With it running if u drip water on the manifolds at ea cylinder the water dissipates immediately except on 1&2. It is getting spark I checked that. The injectors r pulsing u can feel that. I unplugged the front ones on the drivers side while it was running and it didn't change the way it ran. So I'm hoping maybe injectors are clogged. They were changed apparently by the previous owner. The only code it's throwing is for the IAT sensor would that cause it to run this crappy or does it go much deeper? Any help would be appreciated. Thanks
OK in the meantime until you do the compression test have you looked at the wires & cap? you could be a victim of a weak spark or cracked cap cross arching,you may have spark at plug end but is it a strong spark. Are your plug wires oil soaked or showing any signs of possible arching?
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Somethings to consider since your a junior member I'm assuming this 86 is new to you.
Check the wiring harness connectors for bare/exposed wiring.
If your fussing around the vacuum lines chances are you'll crack some. Pickup a foot or tube of small rubber vacuum line to repair those cracked sections.
or if you take Cliffs Scenario swapped down by the plugs #1 & #3 Left front 2 Cyl.
