C4 lift questions
C4 lift questions
My C4 is going on a lift in a couple of weeks for some exhaust work.
My friends lift, lifts the car at 4 points, its not a drive up ramp type.
He asked me what the lift points were for the car, he said they will not be the factory jack points, but they may be close.
I know brake lines and fuel lines are a concern at the rear of these vehicles. Any pointers would be appreciated.
Look at the bottom of the rockers factory lift points are labled.
Pro Mechanic
Use the factory lifting points or something in the vicinity that is a strong, multi-layer, vertical metal "lip". Any lines are recessed from those points. Have a look under the rocker rail of your car....you'll see.
You show him "Toptechx6" snapshot and this from the FSM and mention the "pinch-welds" will be obvious and your friend will be fine. Many lifts similar to your friends don't clear the C4 chassis and you need to drive on 2 X 10's or something to clear. Your friend should know.
Thanks Guys, I appreciate it. My Friend has only owned C5, C6 and C7 Vettes so while willing to help me , he just wanted to be sure he did not dump my car.
