FIC Injectors
Old 05-08-2016, 06:46 AM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
Originally Posted by Mishawaka
35psi after 5 minutes, 20psi after 15 minutes and 0psi after 25 minutes.
My sniffer isn't as good as it used to be, I smelled a little maybe but that could be the errant gas spilled while connecting the the tester. I figured Id see if it would hold a vacuum but it wouldn't, am I correct to think it should hold vacuum?
I have never heard of any pressure regulator that didn't hold vacuum. I've also never heard of a pressure regulator problem causing a starting problem, that didn't also cause a significant drivability problem at all times.
So is the starting problem on cold starts ? or hot restarts, or at all times ???
What was the issue that caused you to replace the injectors in the first place ???
Old 05-08-2016, 08:43 AM
MrWillys
MrWillys's Avatar
A 1992 LT1 is programmed at 23.8. Therefore, if fuel pressure without vacuum applied is 42 a 24 lb injector rated at 3 bar (43.5 psi) should be used. The praise on this board for FIC cracks me up. Individuals need to understand their vehicles and not depend on a salesman for proper replacement.
The OP should also investigate his fuel pressure loss. A properly operating system should not lose more than 10 or 15 lbs in an hour.
Old 05-08-2016, 10:00 AM
Mishawaka
Mishawaka's Avatar
Not sure if the pressure problem happens when hot if that is your question but the starting problem happens hot or cold. My decision to replace the injectors was because it has a slight misfire and set aside money for new ones, I know, sounds like I'm just throwing money at it but that's really not the case here. I drive this car long distances at times and want zero problems with it. next trip may be almost 1300 miles so any new parts are an added bonus for dependability for me the way I see it.(within reason of course)
The pressure regulator concerns me, especially since you say it should hold vacuum. Probably pick up a new one today.
I also think I should probably just go ahead and replace the fuel pump. What are your thoughts?
Old 05-08-2016, 10:15 AM
Mishawaka
Mishawaka's Avatar
No software here to troubleshoot, maybe in the future. I don't know the formulas and details so I have to rely on what I know and learn from others. Are you saying I need 24lb injectors? After reading on here it sounds like the regulator is supposed to hold a vacuum and mine wont so I will replace that. Maybe that is why my fuel pressure drops so quick? Like I mentioned before. No problems at all before with starts or pressure before the injector change so if the problem has nothing to do with them it is a coincidence and will need to look into it further.
Old 05-08-2016, 10:24 AM
MrWillys
MrWillys's Avatar
Your regulator doesn't hold vacuum. If your losing pressure you either have a bad pump or leaking injector(s). Your car needs 24 lb injectors. Can you tell what the number on the injector is? The regulator has a spring in it. When the engine has high vacuum it lower the fuel pressure and when you got wide open throttle and vacuum drops the pressure rises.
Old 05-08-2016, 10:25 AM
antfarmer2
antfarmer2's Avatar
The new pumps will not hold as good as the factory. Make sure you get the right hose to replace the pulsater and a new sock and fuel filter. Get the tool to release the hoses in the engine and take the filter out the top it will save some cussing. If the tank is full disconnect the hose before tyring the filter will save a bath. I would do the o2s while under there. Orielys rent the socket set use the short one.
I have never pulled a vacuum on the FPR to see if it will hold and you have two differant answers so take your pump with you to the store and see let us know.
Old 05-08-2016, 10:51 AM
Mishawaka
Mishawaka's Avatar
OK, just watched a video that had the engine running and they pulled the vacuum line off the regulator and took a few minutes for it to leak. I will try it to eliminate that.
I now wonder if the injectors are pushed completely into the intake and causing the fast leak down. They have two sets of o-rings on that end and the second set may not be where they need to be. There are no visible leaks near the injectors so I figured they were seated properly. I will call Jon Monday at FIC to see why they feel I need 22lb injectors and not the 24s.
The injectors I received are LT1 Bosch 3. The label on the bag reads 22LB@43.5PSI LT1 MATCHED.
If and when I replace(most likely will) I will make sure to get the filter, sock, hose and pulsater. I think I have fuel disconnect tools in my toolbox.
I replaced the O2s last year, drivers side was a pain til I figured if I compressed the converter shield it would allow for me to get the socket on much easier.
Old 05-08-2016, 11:08 AM
antfarmer2
antfarmer2's Avatar
My 94 is all stock and will hold pressure all nite. I had a harder time with my pass side o2. You can not get the pulsater they use hose that can be submerged in fuel only need a small piece but it is something like $20 a foot.
Mishawaka (05-08-2016)
Old 05-08-2016, 11:13 AM
MrWillys
MrWillys's Avatar
Are the injectors yellow? The regulator can go bad but just pull the vacuum hose and turn the key forward and pressure the system and watch and smell for leaks. Mine is original from 1985 and is just fine.
Old 05-08-2016, 11:23 AM
Mishawaka
Mishawaka's Avatar
I would say orange in color.
<br >
Old 05-08-2016, 11:28 AM
MrWillys
MrWillys's Avatar
<br >
Let this be a lesson to those who rave about FIC. Those are either 0280-155-700 or 0280-155-710. The 700 flows 20 and the 710 flows 21. Call them and get the right injector. You need a 0280-155-715 or equal.
Old 05-08-2016, 11:30 AM
Mishawaka
Mishawaka's Avatar
Just wondering, will I have to tune the car? I really would rather avoid any tuning at this point.
Old 05-08-2016, 11:31 AM
  #33
MrWillys
MrWillys's Avatar
Not if you have the right injector.
Old 05-08-2016, 11:33 AM
  #34
Mishawaka
Mishawaka's Avatar
Thanks! I was hoping not since no one has ever mentioned tuning theirs after going to 24s. I just figured that is why FIC sent me the 22s, as to not need a tune. Will call tomorrow and hopefully get things squared away.
Old 05-08-2016, 11:42 AM
  #35
MrWillys
MrWillys's Avatar
LT1's are programmed at 23.8 as I showed you.
Old 05-08-2016, 12:51 PM
  #36
Mishawaka
Mishawaka's Avatar
I went ahead and disconnected the vacuum line at the regulator then turned the key on. sat for a few minutes and no leaks. I then started and let idle for almost 10 minutes, no leaks. I will consider the regulator good.
Then started the engine with everything hooked up and started, at idle it had about 36psi. Then disconnected the regulator vacuum line and it jumped to about 45psi.
Here is a photo of the injectors top o-ring. Does it look properly seated? I know the point is moot since these are 22lb injectors but just wondering.
Old 05-08-2016, 01:49 PM
  #37
antfarmer2
antfarmer2's Avatar
Does it start better with the line off the FPR?
To FIC Injectors
Old 05-08-2016, 01:51 PM
  #38
Mishawaka
Mishawaka's Avatar
I havent tried that. Out and about now in my daily so will try later.
Old 05-08-2016, 02:21 PM
  #39
PatternDayTrader
Are you saying that while the engine is running, its drawing a small amount of air into the intake through the pressure regulator hose ??
Old 05-08-2016, 02:27 PM
  #40
PatternDayTrader
This sounds normal to me.
Quick Reply: FIC Injectors
