Placing Jack Stands on a C4
Old 05-27-2016, 06:50 PM
  #41
project C4
project C4's Avatar
I built these about seven years ago because I didn't like the way jack stands fit on the corvette frame. I have used them on many different cars since then. I own three different sets of large jack stands but always go for these first because they give you so much more working room under the car. I use stands for suspension work only or for safety when swapping tires and wheels .
Joetrackside (09-28-2022)
Old 09-22-2022, 10:24 PM
  #42
chaley
Support Corvetteforum!
chaley's Avatar
Originally Posted by OldPoop55
The stands are placed at the jack points as shown in the shop manual. The front stands are only showing two teeth in height with the rears only showing one. I have grabbed the 'vette and shook it a few times. Certainly seems stable. I definitely did not go up real high on the stands.
If a car is on a lift, shake it real good after lifting it off the floor a bit, if it is good go ahead and raise it up and go to work. If on jack stands, do the same. You will then be safe.
Quick Reply: Placing Jack Stands on a C4
