C4 Rough Acceleration at just above idle to about mid range
So I was hoping someone had the cure or at least what to look for. I have an issue with the engine sounds good at idle and cruising altitude but, when you accelerate is hesitates and bucks at just above an idle until you hit about mid acceleration. I noticed that the temp gauge has stopped working at all and wondered if this could be sending false info to the computer?
Is it the digital gauge? If so sensor for that is on the water pump check that first. Second how old is your o2?
