New 700R4 with 2.84 1st Gear
Old 05-21-2016, 07:22 PM
beerme
beerme's Avatar
Default New 700R4 with 2.84 1st Gear
Hey all,
I just wanted to let everyone know I picked up a new 700R4 with a 2.84 carrier. I am truly impressed with how my car drives now, my 1st gear shift is delayed a bit more which is making the car more fun to drive.
The reason I went to this setup is because I upgraded the engine to 383 and rear-end to a 3.73 which resulted in 1st gear shifting very quickly.
I was unsure about doing a different carrier but this seems to have been a good move, about 500 miles on the tranny so things could change but all in all I am very pleased.
Just thought I would share in case someone is considering this for their car as well.
Old 05-22-2016, 07:08 AM
eutu1984
eutu1984's Avatar
2021 C4 of the Year - Modified Finalist
just saw this video on it, looks good.
tuned (05-24-2016)
Old 05-26-2016, 01:30 AM
odxr
odxr's Avatar
The 700r4/4l60e was originally designed as a 1/2 -3/4 ton truck trans -the reason behind the deep 1st gear.Just in the last few years the aftermarket has came out with the new 1st gear set.Before you had to build up a 200r4-to get a good car type gear spread.
Old 05-26-2016, 06:03 AM
WVZR-1
WVZR-1's Avatar
Received 2,258 Likes on 2,021 Posts
I believe there's little validity to that "generalization". I believe it likely an EPA thing.
The shorter 1st gear allowed certainly taller rear axle ratios to get the vehicle "in motion" and still produce the #'s required. The trans never saw "real 8600GVW" 3/4 ton applications as the higher GVW applications got much shorter rear axle ratios. The 4L60 did well considering the applications it was used in and the generally thought "higher heat" generated through the 1 - 2 wide spread.
OP - with your rear gear choice there's absolutely no doubt that the change improved your driveabilty. Do you notice the 2 - 3 split also or just paying attention to the 1 - 2?
Old 05-26-2016, 08:23 AM
byynow
byynow's Avatar
What is the source of the 2.84 carrier? Is it aftermarket only or can it be adapted from an OEM transmission?
Old 05-26-2016, 08:46 AM
rklessdriver
rklessdriver's Avatar
Sonnax manufactures the 2.84 planetary. PN 77284-K
http://www.sonnax.com/parts/3734-2-8...ut-carrier-kit
Will
byynow (05-27-2016)
Old 05-26-2016, 10:32 AM
BOOT77
BOOT77's Avatar
A powerglide has the same ratio change percentage on the 1-2 on a 700r4, so if you know the why & how a pg works then
Old 05-26-2016, 10:45 AM
BOOT77
BOOT77's Avatar
Originally Posted by eutu1984
just saw this video on it, looks good. https://www.youtube.com/watch?v=-7zf9U_PX3k
Read the youtube comments and watch it again. My TPI only drops to 4k shifting at 5700, but wait TPI can't make power up there???
Old 05-26-2016, 05:40 PM
five7kid
five7kid's Avatar
The video is a bit deceiving. The original 1-2 shift is about 5700 RPMs. The new ratio 1-2 shift pegs the tach before the shift occurs.
Not saying there aren't benefits to the modified ratios, just saying their demonstration was not apples-to-apples.
Old 05-27-2016, 09:08 PM
beerme
beerme's Avatar
My greatest attention has been on the 1 - 2, but the seat of pants feel is the 2 - 3 is more delayed as well but I really haven't been watching that shift point.
All in all I am still really happy with the way the car is driving now.
Old 05-27-2016, 09:40 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
I noticed it too. I DO think that a taller first gear is better for applications like the OP's...but yeah, I saw the same thing. Second vid was probably shifting at 61-6200 RPM
Old 05-28-2016, 09:16 AM
856SPEED
856SPEED's Avatar
They don't...
Have you seen your dyno sheet at 5700 RPM? W/O a miniram or other after market shorter runner intake you are falling flat at 4500 and dropping power quickly at 5000RPM. Sure you can rev it to where you want.....
Old 05-28-2016, 11:53 AM
BOOT77
BOOT77's Avatar
Originally Posted by 856SPEED
They don't...
They do if you know what your doing
Old 05-28-2016, 01:23 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Let see your dynos sheet then.
No "TPI" looking intake that I've ever seen is making meaningful power at 5700 RPM. Some people think there is some "black magic" that can make it work...but the length of the runners and properties of harmonics say that it won't. Dyno sheets pretty consistently show that, too.
Old 05-28-2016, 01:37 PM
pologreen1
pologreen1's Avatar
Well you could make a mint to post and share your info, because the world is full of knowledge and proof that states otherwise.
Old 05-28-2016, 02:16 PM
BOOT77
BOOT77's Avatar
edit: not worth my time
Old 05-28-2016, 11:40 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
A pretty common response when fact checking is brought to the table.
Pologreen is right; if you've unlocked the "secret to high RPM TPI's"...you're sitting on a GOLD MINE!
To New 700R4 with 2.84 1st Gear
Old 05-29-2016, 05:48 AM
eutu1984
eutu1984's Avatar
http://image.superchevy.com/f/914656..._induction.jpg
Old 05-29-2016, 09:48 AM
856SPEED
856SPEED's Avatar
Originally Posted by Tom400CFI
A pretty common response when fact checking is brought to the lytable.
Absolutely! Because
You are working against the law of physics.....
Been there and done that myself with Edelbrock hi flow base and runners and going to miniram......night and day...
Old 05-29-2016, 02:50 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
What is ^this? Context, please?
Quick Reply: New 700R4 with 2.84 1st Gear
