Advice on clutch slave cylinder
Old 05-24-2016, 11:58 AM
pifo1964
pifo1964's Avatar
Default Advice on clutch slave cylinder
Hi Everyone
93 MT Coupe
After changing fluid, the clutch salve cylinder began to leak, so I´m going to change it. Found several brands on the internet, Dorman, Sachs, Luk, Centric, AMS….
Before buying, I would like to receive your recommendations?
To prevent future leaks, should I change the master cylinder also?
Thanks in advance
Old 05-24-2016, 12:09 PM
antfarmer2
antfarmer2's Avatar
I would change both. Seems to be a crap shoot on parts. Many have posted problems with new.
pifo1964 (05-24-2016)
Old 05-24-2016, 12:30 PM
pifo1964
pifo1964's Avatar
Thanks!
I must choose a brand and buy the part. Is one brand a little better or are they all equal??
Old 05-24-2016, 12:57 PM
ovrebo1
ovrebo1's Avatar
Someone will reply with some guys company that remans them, but they are like $150-160....
Old 05-24-2016, 04:13 PM
-=Jeff=-
-=Jeff=-'s Avatar
get a Master and Slave from Jim Jandik:
http://www.powertorquesystems.com/index.htm
Old 05-24-2016, 05:18 PM
ovrebo1
ovrebo1's Avatar
That's the one.
Old 05-24-2016, 05:28 PM
DGXR
DGXR's Avatar
x2
Jim is awesome. He reconditioned my clutch master and slave cylinders, and they are perfect.
Old 05-24-2016, 06:02 PM
pifo1964
pifo1964's Avatar
Originally Posted by DGXR
x2
I will contact him.
Old 05-26-2016, 11:51 AM
pifo1964
pifo1964's Avatar
Originally Posted by pifo1964
I will contact him.
Almost 48 hours since I wrote Jim and still no response, so I bought a Sachs slave cylinder from ebay.
Due to a meeting of classic cars (yes, here the C4 is consider a classic....) I need the car running perfect on june 4.
The part will arrive next wednesday and I have 2 days (more than enough) to work.
And if at some time Jim answers me, I will probably buy his slave cylinder, but right now I´m in a hurry
Old 05-26-2016, 09:27 PM
mwm1993
mwm1993's Avatar
I would just call Jim. He can rebuild your originals. I'm using another brand for now until I get a chance to send my originals to Jim to be rebuilt. I bench bled both cylinders and was able to get a firm pedal almost instantly. For the slave I poured a small amount of fluid into it and moved the rod a little bit and repeated until it was full. Clutch master can be bled like a brake master
pifo1964 (05-27-2016)
Old 05-27-2016, 10:14 AM
pifo1964
pifo1964's Avatar
It is not that simple to send from here the cylinders to be rebuilt....
Good advice here. Thanks!!
To Advice on clutch slave cylinder
Quick Reply: Advice on clutch slave cylinder
